Originally posted by: Nathelion
Regarding superconducting batteries, MRIs are basically giant superconducting batteries (some of them are, at any rate). But the intense magnetic field generated by the "battery" are used to watch the insides of your brain, the whole thing is not used to store and retrieve energy. They are unfortunately HUGE, very heavy, and there have been a number of fatal accidents when metal objects got too close to the coil.
You should see what happens when the energy in an MRI magnet gets released (due to magnet malfunction, or someone pressing the emergency demagnetize button)!
(A magnet malfunction usually happens because a small area of the wire loses superconduction - as the current in the magnet wire is about 1000 A - this produces a lot of heat, causing the neighboring areas of wire to lose superconduction in a massive chain reaction. The emergency stop button actually activates a small heater on part of the wire, to make it non-superconducting).
This happened at my local hospital. The energy in the magnet has to go somewhere, and it ends up going as heat into the wire. The energy stored up to about 10 kWh for a standard scanner, 20 kWh for a high-end scanner, and up to 35 kWh for super-high-field research scanners.
The result is that the helium in the scanner boils, very vigorously, as the wire heats up. The scanner had a 1 foot diameter vent pipe, and when the magnet 'quenched' a huge jet of super-cold helium gas shot out, producing a huge cloud of fog - it looked like some bizarre kind of steam explosion. It was very impressive, but very expensive. It cost about $40k to replace the helium, and about 3 days of downtime, to restart the scanner.
Apparently, we were lucky. In the event of magnet 'quench', there is a very real risk, that the magnet may be damaged (due to sudden uncontrolled temperature rises damaging the magnet wire, massive mechanical forces as the electrical current drops, and pressure build up if the escape of helium is obstructed).
The person in the scanner at the time, felt the magnetic field go as the magnet dumped energy. The field collapsed so quickly, that it induced electrical currents in their body, causing muscle twitches and electric shock type sensations!
This is what makes me uncertain that superconducting energy storage is practical, for anything other than specialist UPS type purposes. You end up with huge magnetic fields, which may end up propagating for a large distance and are difficult to shield. Then, when the energy is drawn down, you get rapid changes in the magnetic field. You have to keep people and critters away, as with a powerful enough system, you could imagine things getting electrocuted from the discharging magnetic field.
