Originally posted by: x2 3600 rules sazakky
http://img138.imageshack.us/my...?image=capture2sn4.jpg][/URL]![]()
pretty sure thats a shot of the motherboard tab...
doesn't matter. already posted
also, i forgot to mention i have three modules. 2 512mb adata 533mhz modules. and a generic 667mhz modules. therefore it is single channel
I can probably hit 2.8 at that voltage (e2140). I had my BIOS set to 1.3V and with droop I ended up with a voltage that low.2.7ghz at 1.264v
I expect two things here to matter. First 512MB DIMMS...yeah these will be tight. Most folks here will assume you are talking minimum of 1GB DIMMS these days.
Second is single-channel. This is far less demanding on the DIMMS. Kind of like 1T vs 2T for command rate, whole other world when you stop demanding dual-channel access timings.
So I recommend pulling a DIMM and testing for dual-channel stability, and even then don't be surprised if most folks aren't impressed with the timings on 512MB DIMMS. We are usually talking about 1GB and 2GB DIMMS these days.
Originally posted by: jaredpace
definitely unusual! what brand is the 1gb, and no slot2 pic?
