A compression problem with my jeep
UDT89
Well i narrowed it down to a compression problem with my 89 wrangler. I each spark plug out and put my finger over the hole and wasnt feeling anything.
What do i do next? How do i determine what it is? What are the possibilities?
89 wrangler
4cly
2.something liter
manual
i think i got an oil leak for sure.......
but the last valvoline that changed my oil never put the cap back on and i blew oil all over the place........so im not sure
If you have NO compression then it sounds like the valve timing might be way off....slipped timing belt/chaing or something related to the valve train.....if it won't start and turns over real fast compared to how it used to then the timing beltis broken.
i think its the top.....there is this thingee that stick out of the top......that is attached to a hose. Looks lose.
Either your doing something wrong or there is something major screwed with your engine. Even the most screwed up compression problem on a engine should give you atleast some pressure.
maybe it's the value. Can you start your engine. I have a 1990 mazda protege. Loosing compression. The car make a dat dat dat noice with the engine on.
Originally posted by: notfred
I don't suppose you've actually considered doing a compression test?
lol.. I was going to say.. Even at 20lbs, you would have a hard time keeping your thumb over the hole.. and a reading of 20lbs would mean a seriously worn engine.
