A CD just exploded in my DVD-RW
Ika
14,264
Originally posted by: theprodigalrebel
my cousin once put a CD in the drive tray...not realising the tray already had a disc in it. When windows autoplay kicked in, things got crazy (he says it sounded like a saw cutting metal...prob an exaggeration). Both CDs were reduced to bits and pieces. It was an aging LG CD-ROM drive so he just tossed it in the trash.
Thankfully, he doesn't hate or blame Microsoft for incorporating Autoplay.
but autoplay wouldn't have changed a thing... if your brother didn't realize there was already a CD in the tray, he would've loaded it up anyway and it would've started to spin anyway, just like it did under Autoplay.
buck
12,273
4
If you were able to get all the pieces out and get it to work, would you want to use it again. ;)
New NEC dvd burner FTW!
Oyeve
22,071
885
I had a cd-r blow up in a mac G4 tower. It was shortly after 9/11 and the sound of the cd blowing to bits caused the company to evacuate the wharehouse. The sound was heard through 4 floors!
rivan
9,677
Shens?
Oyeve
22,071
885
Shens?
No, really. The watch company is owned by Orthodox Jews and we all thought the worse. It was scary until I realized it was the stupid mac blowing up the disc. Was a scary time man.
ajikan
4,338
haha, I think this happened to me once. The drive ended up being dead. >__<
Was playing Starcraft and it broke the CD into 39280740234 pieces.
buck
12,273
4
Shens?
4 floors? Your office made of a deck of cards? Shens.
ForumMaster
7,792
hmm. i remember back in the day when i was trying to read an audio cd in this Lite-On burner. the burner still works great. i just vacumed it and took all the pieces out. it's in my dad's computer and he doesn't use it much, but i can still hear pieces inside. the theory here is this: if it ain't broken, don't fix it.
Oyeve
22,071
885
Shens?
Shens? What? Are you guys 10 years old? The thing sounded like a gun shot! A BIG gunshot! The whole cd drive blew out as well as the cdr.
biostud
19,965
7,056
Originally posted by: bX510
This is the first time i ever heard of a cd exploding... AND a cd LAUNCHING?!?!?
guess what will soon be banned on airplanes :p
ForumMaster
7,792
once when i was trying to read a cd, it exploded inside the drive. i opened the drive and vacumed what i could. the drive still works. i should take it apart since it's way out of warrenty now but as they say, if it ain't broken, don't fix it.
CrashX
1,125
Happened to me just the other day. One month old Lite-on. I put a blank CD in and the machine didn't recognize it as a blank disc. So I took it out, but a different disc in and burned it. Later on I put the first one back in, it spun up and then BANG.
It was SERIOUSLY loud. I jumped out of my seat. The computer is on my desk and I thought it was a gun shot.
I didn't bother to take it apart as I figure it's probably toast.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Where are they getting the 30,000 rpm figure from?
As they found it took a seriously powerful router to get that speed over 25,000 rpm! The spindle motor on a CD drive is not nearly as powerful. Even though the insides of the drive are better optimized from an aerodynamic standpoint, the amount of electrical power required would be far greater than a small PM motor that's used.
If you do the math, reading a cd at single speed on the innermost tracks at 550 rpm would require > 30,000 rpm to achieve the rated speed. But there's a catch. CD's are recorded in a way that one must vary the speed to maintain the same data speed. (CLV) The newer drives (started after 8X) were CAV which meant they were capped on the innermost tracks and would only achieve the absolute max rating on the outermost tracks.
The same is true today with 48X units. Most start out around 16X speed on the inner tracks. This is roughly 8800 rpm. Still very fast but a far cry less than 30,000! The fastest drives begin at 24X (around 13,000 rpm max) which is less than half the seemingly critical mass speed of 30k. :)
secretanchitman
9,353
23
around $40 is a brand new NEC 3550A dvd-rw on newegg.
sorry to hear about your drive. my bet is that its totally screwed up now, or that it will perform a lot lower than expected.
Kinslayer777
202
I've seen videos where people load cd's on dremen tools and launch em - BOOM! :)
BUt, yes, most likely your drive is broken or theres some miniscule peice you'll never find that isn't worth risking future disk (if it scratched them)
