Even Xubuntu is too heavy to run in less than 256MB of ram. It's basically a stripped Ubuntu running a lighter GUI.
Both of which can be customized however you like. You can install Ubuntu and just use e16 or fluxbox if you like, the only difference is the set of default packages installed.
Well, Fluxbox isn't substantially lighter than XFCE, and really starts to cut out on functionality. In general, the packages the buntus use are too heavy to be a good fit for systems with less ram and you really should be looking for a dedicated light weight distro once you drop below 256MB.
