Originally posted by: GodlessAstronomer
Originally posted by: MrDudeMan
Originally posted by: Atomic Playboy
Originally posted by: mwmorph
The Apache uses a single barrel autocannon capable of 625 rounds per second. The A10 uses a 3900 round per second, 7 barrel system. They can share ammunition, both build to 30x173mm rounds, but the GAU-8 in the A10 usually uses 4 AP and 1 HE ratio while the M230 tends to use more HE rounds.
Also, the usual range pilots try to use them are around 1200-1500yards. 2 miles is technically doable, the ballistic profile of the bullets will do tat range, but accuracy will be a bit of a problem.
This is what an A10 sounds like, completely different sound profile:
http://www.youtube.com/watch?v=sALiuWg_I1k
That's what 10k lb/ft of recoil sounds like.
I'm assuming you mean rounds per minute, not second. A gun firing 3900 rounds per second would be absolutely insane.
Text
Well excuse me if I'm extremely skeptical that a million rounds were fired independantly in that last volley.
You're right. That's just the rate that it was firing, not that a million rounds were fired. I don't think that idea will catch on because the rounds are all stored in the barrel, limiting the capacity.
