Originally posted by: ElFenix
i've seen it happen. pulled straight from the fuel tank of a cessna.Originally posted by: Pacfanweb
You have that backwards. Avgas is LESS volatile than regular gas, so it evaporates SLOWER. Try it sometime, and you'll see. That's why it's hard to start race cars in cold weather....the gas is harder to ignite.Originally posted by: ElFenix
he could be running avgas. that stuff is so volatile that if you pour some out of a vial on a warm day it will evaporate before it hits the ground.
Originally posted by: Dead Parrot Sketch
"BTW: The LS6 is only rated at 405 HP"
That's the wrong LS6. The Chevelle came with the big block 454 LS6, factory rated at 450hp.
Do a google search for chevelle and ls6 to see some examples
And yes, once again, Avgas, or high octane racing gas, burns SLOWER, and IS HARDER TO IGNITE. It is less volatile than regular auto gas.
And whoever said they saw gas taken from a Cessna and let evaporate, I'll bet you didn't see it side by side with some regular unleaded, although I fail to see how evaporation rate has anything to do with volatility. Alcohol burns MUCH more slowly than gas, yet it evaporates instantly.
Ok, you got me on the technicality, but the fact remains that Avgas or high octane race gas burns slower and is harder to ignite than regular unleaded car fuel, which is what we were referring to, regardless of whether we were using the word "volatile" correctly.
And I still don't believe Avgas is more volatile than regular, even by the correct definition.
