exdeath
- Jan 29, 2004
- 13,679
- 10
- 81
#4 is the rear passenger cylinder, Ford engines are labeled:
rear
4 8
3 7
2 6
1 5
front
Make sure the coil pack cover seal is clean and the rubber grommet where the signal wires enter is seated right. Lining up those grommets can be a pain, so most people just slap the cover on and bolt it down smashing the grommet or whatever, allowing moisture into the coil packs.
grommet |- =| under side of coil cover
rear
4 8
3 7
2 6
1 5
front
