Originally posted by: w0318
hey guys my counterstrike wont go above 60fps. plus the pc beeps when i play cs but its smooth no issues. what gives?
Generic 320 PSU
2.4
8inxp Gigabye board
512 266
9800pro
XP pro
i am ripping my hair out.
so the monitor refresh rate affects my fps. ??
Technically no...but refresh rate is a VERY important aspect that many gamers overlook. There is no point at all of getting above 60 fps when your refresh is locked at 60 hz. I would also pretty much guarantee that you have vsync on.
1) turn off vsync
2) download reforce from ftp.thecpl.com and set your refresh rate for your in game resolution (most professionals use anything from 85-120 hz...but make sure you don't go over the specs of your monitor)
3) set fps_max 100 (you can actually go higher by typing: developer 1....then fps_max 500...or whatever fpsmax u want)
4) lower your sensitivity because refresh rates affect it BIG time.
happy fraggin....
technically yes, it does effect your fps when you have vsync on. that is why we turn vsync off for benchmarking, to see the framerate the card is capable of instead of the limit imposed on it by doing what is best for image quality on the monitor.
1) don't do that unless you like torn images beter than solid ones.
2) that is unnecessary as ati has a refresh override option built in to their drivers.
3) i suppose, if you like tearing and disable vsync. otherwise you might as well set fps_max to your refresh rate.
4) that doesn't even make sense to me, but if figured i'd give the benefit of the doubt and try it; the mouse moves the view the same amount at both 85hz and 60hz.
