9800pro vs 6800xt
lookouthere
552
9800pro vs 6800xt which one better? i mean 9800pro for $70 and 6800xt for $130. which one is better considering the price gap? thx for the feedback
lookouthere
552
yea i know it will crush 9800 but consider the $50+ gap, is it worth buying 9800 at that price?
Dec 22, 2005
It's a decent price if that's what you mean. Radeon 9700's go for around $50 on ebay used. A 9800 Pro will be a bit better so a slightly higher price.
lookouthere
552
so 6800xt will almost provide twice the performance as 9800pro? if so, i gonna order it. thx
beserker15
820
no..it won't. and it will also depend on which 6800xt you're talking about (aka, make and clock speeds). a regular 6800xt is about as fast...maybe even slower than a 6600gt...which is no where twice as fast as a 9800pro.
lookouthere
552
if i was lucky to unlocked 4 piple and overclock to 375/800? will it give twice as performance?
Captante
30,354
10,880
Maybe not quite twice the performance, but pretty close to it ... a 6800xt stock is very close to the same as a 6600gt, but with all pipes unlocked it becomes a 6800nu ... faster then the 6600gt in most games, but not a night & day difference... in order to see a really big jump in performance you would have to jump to a 6800GS or GT & they cost considerably more.
Munky
9,372
A 6800xt will be about as fast or slightly faster - definitely not worth the $130 pricetag. For around $130 you could get a faster 6600gt, x800/gt/gto, or x1600.
A554SS1N
804
A regular 6800XT will be crushed by a 6600GT, and overall beaten by a 9800pro. The only 6800XT I'd go for is the Galaxy, which is overclocked to 425mhz core, 1000MHz DDR3 memory - and turns out similar, if not slightly faster than 6800 vanilla performance (depending on the game) according to the Guru3D.com review. A 9800pro would still be a nice card to get if you're on AGP, especially because they're cheaper.
acemcmac
13,712
Is it your position that a 3.5 year old chipset is really better here?
I have a 9800AIW and am trying to make this last as long as possible... I don't understand how there can be any truth to what you are saying....
acemcmac
13,712
6800XT with 512 onboard can be had for $150. I would think that would be good bang for the buck to take an i875 with a P4 2.8 to end of life. What do you guys think? Again, I'm going from a 9800AIW to anything nvidia.
kmmatney
4,363
The 6800XT is not fast enough to use 512 MB - the memory size is a gimmick. The 6800XT is slow to begin with, and the extra memory will probably just hinder overclocking. The 6800XT only has 8 pixel pipelines. Some can be unlocked to more pipes, while others are hardware disabled.
For $155 you can get something more sensible:
http://www.newegg.com/Product/Product.asp?Item=N82E16814131010
or for slightly more for one that unlocks to 16 pipes (recommended):
http://www.newegg.com/Product/Product.asp?Item=N82E16814102608
or if you don't mind open box:
http://www.newegg.com/Product/Product.asp?Item=N82E16814102609R
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
Hey, thanks for all that info. After some more researching I think I'm gonna buy a Sapphire x800 gto. I have a 9800 pro currently that's suffering in Oblivion and I hope to fix it :).
Captante
30,354
10,880
If you can swing the $165 for that Sapphire X800GTO then thats the best option by far performance-wise, a 6600GT from the FS/FT forum can be had for about $90 so that & the $110 6800XT are pretty much a wash IMO ... really I think your best off going with a 9800 Pro/XT from FS/FT because they can be had for about $70 & in reality are faster then you'ed think they have any right to be... the 9800 Pro is the slowest card you should consider though IMO... the 9700 Pro is just enough slower to not be worth the small $ savings.
