9700 Pro problem
Tullphan
I recently installed Watermill Screensaver v1.1 on my & my wifes' machine. See "My Rig" for my system details. She's using a 128mb Radeon 8500LE w/1.0 ghz AMD & 512 mb ram. It seems that when the screensaver is running, about every 3 seconds there's a "jump" or "pause" on mine. Hers doesn't do it.
Is this an issue with my card? I've got the Arctic Cooling unit on it as well as a side panel fan, so I don't think heat's an issue. Also, my card (nor hers) is overclocked. What gives??
could be something else running in the background causing problems, or maybe just a botched driver install. if you don't have the 4.3 drivers already you might as well get them now.
