Just to let you know... with the bnc used you can't use dcc and you can't set the monitor
max res or refresh rates.
They are greyed out because ATI says ok you installed our drivers and your monitor
settings but since I can't read anything from your monitor YOU don't know enough
to set the correct monitor inf file so I better be safe and protect YOU since you are an
idiot.
Are you even paying attention? I do use BNC cables, with ATI cards in my rigs, as do other posters in this thread who are trying to help you. BNC cables do not support DDC, they don't send info back from the monitor. This is true no matter what video card you use. That is why with an ATI card, you need to go into the advanced display properties>into the display's monitor property sheet> and UNCHECK "use DDC information" if it is checked (It says "unsupported" on mine) and under maximum resolution, set it at the HIGHEST supported resolution for your monitor. Mine is set to 2048x1536. Then you need to set the HIGHEST refresh rate supported by your monitor. Mine is set to 200HZ. I use 1600x1200@85HZ for my desktop CRT setting.
Note that there is also a setting for forcing the DX refresh rate to whatever your monitor supports.
More to the point ATI won't say a damn word about this. Seems that they want the ms
Search is a skill....not a right.
We will not allow the user to fry their monitor so we won't allow them to do anything
Now you're making sense....
set everything with a std monitor cable and it works fine. Now I am going to go back and try the bnc cables and see if it will keep the current settings.
I agree, follow the steps outlined in the link should work the first time.
and like I said before go to rage3D 100's of post on this same thing with ATI drivers
and their 60hz block.
Exactly, stuff like searching and paying attention to helpful tips escape a great many PC users....even at Rage3d.
They sure want that new XbOX deal so whatever Microshaft says they will do.
You my friend, are on a roll...yea baby.
Good luck!
