9600GSO to 4830?
mindless1
8,798
1,781
Some of them respond well to voltmodding and some don't. My 9600GSO (Newegg calls it "EVGA 384-P3-N966-TR GeForce 9600 GSO 384MB 192-bit GDDR3", the one with the double-height rear exhaust aluminum heatsink), was voltmodded with the hope of better performance but it barely clocked any higher and heat wasn't yet the issue. Due to this I accepted the ~ 5% lower o'c, keeping in mind these are chips nVidia has the underfill and solder bump problem on so they should last longer if not pushed to their short-term limits. With and without the voltmod it initially seemed like the card could do about 720 core, 1060 memory, but after testing with ATI Tool for a few hours it turned out that the card couldn't stay 100% stable till backed down to 640 core, 960 mem. at full fan speed. It might've been stable at 660/980, I usually subtract 20 to give a little margin then with that confidence level I can go ahead and flash a modded bios to make it permanent.
Funny thing is, backing the fan speed down to 40% didn't cause a significant rise in temperature, only a single-digit # of degrees. Next I took the 'sink off, lapped the area over the core and put AS grease on. That gained 3', not enough to have bothered with especially when the memory seems the bottleneck but it wasn't even getting warm enough to bother with heatsinking.
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
Hmm... choices choices. I just put myself in the same situation - I have a 9600GSO and noticed Newegg has the Sapphire 4830 on sale for $85 today. To bite or not to bite...
AzN
Banned
Nov 26, 2001
4,112
I don't think it's worth it unless you are hurting at the resolution you play. 10-25% faster. It might be more faster with AA though.
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
1920x1200... I'm always hurting.
AzN
Banned
Nov 26, 2001
4,112
At that resolution you should. 4850 wouldn't hurt either. Saw one for $115 after rebate looking at hotdeal section.
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
I would obviously prefer a 4850 or even a 4870, but my upgrade budget is always modest at best, and I'm also trying to save my pennies for a Phenom II 940 at the same time.
