'93 Taurus: what does "max AC" do?
CubicZirconia
5,193
I always use the Max AC (or Recirc) setting...esp. when behind some vehicle with a smelly exhaust or burning oil or something.
Now here is where one could properly use the phrase "do you want a cookie?" Not that I am, but it would make sense in this case.
Who put you in charge of the cookie jar?
:p
I overthrew the old cookie jar rulers. I now regulate all tossing and giving out of cookies.
Yeah...you just LOVE to toss, don't ya?!
wtf
y'know, toss?
good lord
Cyberian
9,999
Originally posted by: thomsbrain
the fan will blow "harder" because there is no pressure it has to work against, since it's taking out what it's putting in. try rolling down your window, you'll get the same effect (but without the extra fan noise caused by the intake). there's no difference in fan speed. it will blow "colder" because it's taking air it has already cooled and cooling it again.
japanese cars can do the same thing with any heat/vent output/AC combination. those pitiful Ford HVAC controls never seem give you all the options. ;)
edit: "MAX" A/C actually puts less strain on the engine and improves gas mileage because the A/C doesn't need to be cycled on as much to cool the cabin. Honda mentions this in their manuals.
Huh?
You lost me there - what pressure?
TechnoKid
5,575
Cookie? I would have asked for a fig newton, which is actually fruit and cake, not a cookie. j/k :p
NinjaGnome
2,002
:p
You want a cookie?
Fiveohhh
3,776
Cheers for the 93 Taurus!... Mines a SHO though..
as far as your question I'll say what others, just takes the air from inside the cabin as opposed to the outside. that way it only has to cool air from whatever temp the cabis at instead of the heat outsdie...
NeoPTLD
2,544
Gas mileage difference is probably minute anyhow. I heard A/C is better for gas mileage than leaving windows open at highway speed.
CubicZirconia
5,193
:p
You want a cookie?
He asked a question, I gave an answer. Yet another incorrect cookie usage. Nice try though.
