'93 Taurus: what does "max AC" do?
dpopiz
4,454
I drive a '93 Taurus GL wagon. I've noticed it seems that the only difference between "norm AC" and "max AC" is that "max AC" makes the fan blow harder. it doesn't seem to actually make the air any cooler
Eli
Super Moderator | Elite Member
8
It makes sense that it would only make the fan blow harder(which would probably actually warm the air slightly), as an A/C compressor is either on, or off.. I don't think there is a way to adjust the temperature of the airflow without using some mechanism to cycle the a/c.
Feldenak
14,090
Originally posted by: CubicZirconia
I drive the same car, max ac definately seems cooler to me.
I'm not sure that the air is actually cooler but it cools the cabin down faster because it is cooling pre-chilled air instead of cooling the warm outside air.
dpopiz
4,454
hm cool! so that means that I don't have to worry about putting even more load on the engine with max AC
CubicZirconia
5,193
I drive the same car, max ac definitely seems cooler to me.
At any rate, I am cooler when running max ac.
want a cookie?
This is the worst use of "want a cookie" I have ever seen. It doesn't fit at all. Shame on you.
conjur
58,686
I always use the Max AC (or Recirc) setting...esp. when behind some vehicle with a smelly exhaust or burning oil or something.
CubicZirconia
5,193
Now here is where one could properly use the phrase "do you want a cookie?" Not that I am, but it would make sense in this case.
conjur
58,686
Who put you in charge of the cookie jar?
:p
Nebor
29,582
12
I'm on my second ford truck, and it also uses the AC and MAX AC settings. MAX AC simply recirculates the air in the cab, while AC pulls in outside air. Does the same thing as the little button w/ the circular arrows on Volvos\Acuras.
CubicZirconia
5,193
:p
I overthrew the old cookie jar rulers. I now regulate all tossing and giving out of cookies.
godmare
5,121
The fan doesn't blow harder, the extra noise is from the air intakes inside the cabin.
Eli
8
You would think people here would be able to feel a simple increase in airflow. :p
Eli
8
and it will get louder if you put something in front of the intake....like a deflated saftey man
Whiskey Tango Foxtrot, over
thomsbrain
18,148
the fan will blow "harder" because there is no pressure it has to work against, since it's taking out what it's putting in. try rolling down your window, you'll get the same effect (but without the extra fan noise caused by the intake). there's no difference in fan speed. it will blow "colder" because it's taking air it has already cooled and cooling it again.
japanese cars can do the same thing with any heat/vent output/AC combination. those pitiful Ford HVAC controls never seem give you all the options. ;)
edit: "MAX" A/C actually puts less strain on the engine and improves gas mileage because the A/C doesn't need to be cycled on as much to cool the cabin. Honda mentions this in their manuals.
conjur
58,686
:p
Yeah...you just LOVE to toss, don't ya?!
ElFenix
102,393
8,552
ford hvac controls are stuck solidly in the 60s for some reason.
CubicZirconia
5,193
:p
wtf
godmare
5,121
:p
wtf
y'know, toss?
