Hi. I have a HIS 9200SE which has never worked properly from day one. When I boot the pc up and get to the desktop is shows little red dots everywhere and they won?t go away until I restart the pc. My questions are these, has anyone had this problem before? what is likely to have caused it, can it be fixed with say a bios/firmware update and if not how long do you think it will last if I try and clock it up to a 7800GTX to blow it up so I can get a new card that will work?.
Thx
Thx
