Hey guys,
I just bought a brand new Gecube Radeon 9200SE PCI graphics card to use as a temporary replacement in another computer while its graphics card is going through an RMA, but I am having no end of problems getting it to work.
When the card arrived, I decided to test it in my main computer as I currently do not have access to the computer that it was intended for, so I took out my X1800XT and booted up the machine with the 9200SE in one of the PCI slots but nothing appeared on the display. I tried the 9200SE in my two other PCI slots with no results, and tried switching the BIOS graphics option from PEG to PCI, again with no results.
Then I put my X1800XT back in, set the BIOS back to PEG, and tried to use the 9200SE alongside it. The X1800XT started up and the stock cooler made its typical 100% spin-up noise (at which point it usually spins back down to about 35% right away), but the fanspeed stayed on 100% and nothing appeared on the display no matter which card I had my monitor plugged into.
Cliffs: -
1.) Tried 9200SE on its own with BIOS set to PCI graphics, no display.
2.) Tried X1800XT (pri) and 9200SE (sec) with BIOS set to PEG graphics, no display and constant 100% fan speed on X1800XT.
Any ideas?
Edit: I should've mentioned that I tried this both with and without any ATI display drivers installed on my machine, but that makes no difference as it won't even POST never mind get around to loading drivers.
Cliffs: -
Any ideas?
