Page 86 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
BFG10K
22,709
3,007
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
psolord
2,142
1,265
I am posting the same frame from the GTX 970. 1080p, fsr balanced, medium preset.
There's a difference of course, but considering the delta between these two cards, the GTX 970 ain't atrocious. That's just to show how beautiful UE5 really is and how you absolutely must not use FAFO settings.
A new Frostpunk 2 screenshot. This game is funny because one screenshot can show you what to expect.
Anyhoo, rx6600 this time. 1080p/fsr quality/high preset.
Yes you can have a perfect 60 on the rx6600, if you don't go over 9000 with the settings. And on a 2500k no less.
DAPUNISHER
32,456
33,484
Side note to anyone - I'd like to know if texture popping is still a current issue.
Indeed it is. Sometimes it isn't a vram issue though. Probably just the way the game handles draw distance, streaming, and filtering.
When Aloy jumps and glides you see the same pop in on the ground below her regardless of whether you have 6GB at medium or 16GB at max.
vids will start at correct times.
DAPUNISHER
32,456
33,484
@SolidQ
Are you expecting that game to have issues with 8GB of vram? Because that's the topic of the thread; games requiring more vram now. And the screenshot you shared shows a 3070ti as recommended and it has 8GB.
On topic: Aussie Steve just revisited the RX 5700XT. More AMD fine wine. 🍷 But what was interesting is when he exceeded the 8GB in Ratchet&Clank there was no impact on fps or frame pacing. It simply didn't render the textures properly. Yet another nail in the coffin of bigger bar better. At some point old dogs need to learn new tricks. Because bar charts are outdated without accompanying gameplay video or commentary about the actual in game experience that point out issues like that. Otherwise here in 2024 it amounts to gaslighting.
I am seeing tech tubers that are nothing more than DIYers with a camera do positive reviews of the RTX 4060. "Hurr durr it's not that bad, what's all the fuss about?" Then in the comments section acknowledge that it's overpriced for 8GB. Something they don't emphasize on camera. Instead using whataboutism "It's only a little more than the RX 7600." Uh huh. And that's a card flying off the shelves eh? They both suck, that's the whole point. Doing several videos to show it sucks less than AMD's overpriced entry isn't the flex you think it is. Around $200 is the most anyone should be paying for 8GB now. That there is a $400 8GB card is proof suckers are born every second.
Ranulf
2,921
2,602
Early reports on No Rest for Wicked are "huge fps drops and stutters" on a 4090 w/14900k. More serious I think is no re-bindable keys but it is early access.
EDIT TO ADD: Game lists min specs as a 970/Vega 56. CPU is 8400/2600.
DAPUNISHER
32,456
33,484
Early reports on No Rest for Wicked are "huge fps drops and stutters" on a 4090 w/14900k. More serious I think is no rebindable keys.
Explain what an early access title has to do with the topic please. Otherwise it's simply derailing the thread which is no bueno.
Ranulf
2,921
2,602
It was mentioned twice above so I thought I'd chime in but delete it if you want. Perhaps I also forgot to add in that the min gpu specs for the game are a gtx 970/Vega 56.
DAPUNISHER
32,456
33,484
You don't need to delete it. But let's stay on topic. There is so much here that's on topic and still a chore to wade through if you don't use the ignore feature ;) That adding to it with off topic commentary makes reading the thread insufferable.
jpiniero
17,213
7,588
It's rendering the textures properly... it's just using the LOD texture until the real texture finishes loading.
(It should be fast to load in R&C given it's using DirectStorage... the fps hit from using the shaders OTOH...)
Reactions: DAPUNISHER
blckgrffn
9,687
4,348
www.teamjuchems.com
LMAO, that's such a "WORKS AS INTENDED, TICKET CLOSED" response it makes my skin crawl.
Yeah, but is that "works as intended" the same as "works as customers expect"? Or in a way that avoids disappointment? Those can be vastly different things, and that would be the same case here IMO.
It can work as its supposed to and still be considered defective.
SolidQ
1,542
2,547
Need test in 1440 and higher
You can rename topic like 8/10/12GB VRAM not enough and Optimization in a games.
That would be good topic for tech speaking.
coercitiv
7,506
17,946
Here's your reply being rendered properly while the browser is still loading vowels:
It's rndrng th txts prprl... t's jst sng th LOD txtr ntl th rl txtr fnshs ldng.
(t shld b fst t ld n R&C gvn t's sng DrctStrg... th fps ht frm sng th shdrs TH...)
jpiniero
17,213
7,588
I have no doubt that developers could build in intelligence to better manage the VRAM. They won't though.
psolord
2,142
1,265
Brand new numbers, 3060 12GB has higher 1% low than 4060 8GB in:
Dying Light 2, Battlefield 2042, Avatar Frontiers of Pandora, Call of Duty Modern Warfare 3, Starfield, Forza Horizon 5, Horizon Forbidden West, Alan Wake 2, The Last of Us, Tekken 8, FC 24, Detroit Become Human, Death Stranding, Alone in The Dark, Overwatch 2.
And now, back to your usual scheduled lunatic flat earther ranting. Everyone else is wrong, yo!
Another 1440p example, on upper entry level cards, good job! Why don't you find a 8k test next, where the 3060 would give 3fps and the 4060 only 1fps? You could then add a 300% performance claim, solely based on vram!
The fact of the matter is, that the 4060 remained consistently faster and in the games that the 3060 had a win in 1% lows, the win was small in most of them. What is even worse, is that in the games that they were unplayable, they both remained unplayable.
Also I love how there is a 16GB card in there, which the 8GB card is very competently fighting and actually beating in a few cases, at 1440p ultra/very high settings no less and you posted this with a straight face, lol.
psolord
2,142
1,265
The thread didn't invent VRAM problems. The effects of not enough VRAM are known as far back as the late 1990s and are well-established. I just list examples where it applies to 8GB.
Well to me, when you post things like Deliver us Mars at 1440p Ultra+RT, on an 8GB card, compared to a 12GB one, where they both fail anyway, but the 8GB card fails harder, is not much of a usable proof. This looks like vram problems invention, especially where they are easily fixable with correct settings and minimal image degradation.
There was no focus on resolution, ever. That was caused by a goalpost shifting individual that doesn't understand elementary 3D rendering concepts and constantly posts misinformation, sprayed with an explosive diarea of screenshots.
Not having a resolution focus is wrong and that's why I put it there. It's basic gpu knowledge. Sure there are some games, that are problematic from the get go. I have admitted to this. They are drops in the ocean in the grand scheme of things. What's even worse, is that they are easily fixable and you deny to see the fix. I mean I showed you what the ultra texture preset does in TLOU with what image degradation.
It's not goalpost shifting. It's real usable info. Use correct settings, game goes back up to being playable, image quality is great. You chose to be fixated on the problem, not my fault. And all that, in very few corner cases, where most of them are specifically games from the playstation ecosystem. Coincidence? I don't think so...
The same reason 320MB wasn't enough on 8800GTS in 2007.
The same reason 4MB wasn't enough on i740 in 1999.
Not the same thing. Different eras. We had 1080p screens back then too. We have 1080p screens today. But we have 8 whole freagin GBs to fill the screen. Textures and other assets can only get SO good. You need to go with sub pixel sized assets, to make 8GBs fail. Or RT, which will hamper the gpu too.
We were told 1440p isn't "a proper setting" for $500 GPUs, so I provided plenty of 1080p examples. Notice how he stopped short saying 1080p isn't "proper", but then says it needs upscaling added. A lie by omission since 1080p + upscaling is 720p.
I never said that ffs. I said that I never cared for the 3070/3070 ti and that's why I got the 3060ti. Never disappointed me. Why? Because I don't crank everything over 9000. I don't do that even on my 4070ti. This never ends well. You have to understand, that settings are there for a reason and one of the reason actually IS, to make people spend more money. You tone down a couple settings, boom, problem gone, you saved a tier of graphics card.
Also I don't remember where I used upscaling as an excuse like that arbitrarily? I showed my 3060ti with DLAA on Horizon Forbiden West and Alan Wake 2. Run like charm. I did not use DLSS on my TLOU screenshots. I only used FSR on my lesser 8GB cards and that was due to gpu power and not vram issues.
Also, either you like it or not, upscalers are here to stay and with good reason. Games are heading to disastrous gpu power requirements first and foremost and a good quality upscaler will be a necessity.
Also there's the matter of power draw/heat. I was playing Bee Island at 4K on the 4070ti and it had more power draw, than A plague tale requiem at 4K/dlss. That's ludicrous.
psolord
2,142
1,265
Giving a next gen game a small and ugly texture pack for that little install base serves as a way to serve low spec PC gamers too. Win/win? ;) LOW SPEC BEING EVERYONE WITH AN 8GB OR LESSER GPU FOR THOSE THAT AREN"T PIKCING UP WHAT I AM LAYING DOWN. :D
The 8GBs of the Series S, is the least of its problems. It's the 4 glorious tflops that are holding it back and the locked ecosystem. My rx6600 also has 8GBs. Runs Baldur's Gate 3, Remnant II, A plague tale requiem at 60fps. Only 30 on the Series S. It can also run Ratchet & Clank, TLOU, Spiderman, HZD, Godfall, The Last Epoch and even Mario Kart 8, much more successfully than all the XBOXes combined can do. If you get my drift....
The RTX 3060ti is way more capable than the rx6600. Still 8GBs.
Timorous
1,989
3,918
The primary issue is that the inflection point of current performance / estimated future performance for an 8 GB card makes it not worth much more than $300 at most and realistically $250 or less.
The 4060/7600 and 4060Ti 8GB are all varying degrees of bad value for this reason. The 3070 got away with it more because that card is approaching 4 years old already so turning down some settings to make it work is less of a problem.
With equal compute the correct settings for a 12/16GB card will sometimes be a lot higher than the correct settings for an 8GB card. As we can see there are cases where the 12GB 3060 can provide a very playable experience where the 3070/3070Ti/4060/4060Ti 8GB/7600 all suffer due to VRAM limits. Yes you can turn the settings down on those 8GB parts to make it work but why should someone who has one of those cards need to turn settings down that the 3060 12GB owner does not need to? They purchased a last gen $330 card so why is it beating last gen $500/$600 and current gen $300/$400 cards? That should not at all be the case in any scenario.
So it is not that we don't get that you can 'fix' the issue by turning down IQ because that is trivially obvious. It is that the price point of some of these products means they should not be having this issue in the 1st place when less than $50 of extra VRAM solves it from the vendor side and makes it a non issue it just reeks of planned obsolesence.
EDIT: The final point to make here is that generally games scale really well with varying amounts of compute. When it comes to textures and VRAM they are less graceful. If the lowest settings fits in the VRAM buffer fine but if it does not you are either going to have severe hitches or lots of texture swapping. Right now the lowest settings do fit in the 8GB buffer but I do think we will start seeing more and more games where even the lowest texture settings is borderline. TLOU was somewhat like this at launch and it received tons of backlash so the devs worked on it but I don't see that being the norm. Titles will launch where 8GB is only good for low textures and they won't be worked on to improve the situation. It is just a matter of time.
Aapje
1,530
2,106
@Timorous
Indeed. And don't forget that increased texture quality generally puts close to zero extra load on your system. I prefer having the same level of graphics quality by upping the texture quality and having a cool card that draws less power, over having to brute force it.
SolidQ
1,542
2,547
Arc seems pretty terrible in Fornite
Status
