Page 143 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
BFG10K
22,709
3,005
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
DAPUNISHER
32,121
32,697
TLDW = There should not exist a situation where the B580 is faster than a 5060ti, but there are a number of examples here. Some are expectedly embarrassing; some PS5 ports are kryptonite for the 8GB card. Both are tested in the best case scenario PC setup for each card.
19,204
One of the worst examples in that video:
This isn't madness. This isn't about settings. The 5060 Ti has been castrated and the wounds are permanently fresh and raw!
I guess this doesn't matter for the future of gaming coz Nvidia will soon debut their virtual games player agent that will play the games on the gamer's behalf and then speed up the gameplay video so the gamer can enjoy the show one day later!
Thunder 57
4,133
6,890
Have yet to watch but this but if true AMD should do what I said awhile back and limit the 6060 XT to 16GB. Maybe allow 8GB for the vanillia 6060.
EDIT
I forgot to add the obligatory "But muh DLSS!". Not sure if they used that in the video.
19,204
Interesting that will be minimum like 16GB, optimal 24-32GB(We know PC version will get advanced effects)
Maybe 12GB minimum with normal textures. 13GB minimum with high textures. Very High could be 16GB and Ultra may need more than 16GB.
They want to sell 100 million copies at the very least so can't set Ultra to 32GB. Has to be between 20GB and 32GB. Maybe special features for 5090 to use the extra RAM if Nvidia pays them.
Reactions: Tlh97 and Ranulf
SolidQ
1,524
2,501
I'm assume PC version will be same as PS6 + More RT effects. Here seems base consoles have RTGI(which confirmed) and RT reflections
Reactions: Mopetar
Mopetar
8,507
7,762
The 1% lows are horrendously atrocious on the 5060 TitaniumCrap Edition.
They should really rename it. That card doesn't deserve to beat the Titanium moniker. They should pick another element instead.
I think Arsenic accurately describes how poisonous the card is to high frame rates and smooth frame timing. I dub thee 5060 As!
If anyone can figure out how to work another 's' in there at the end it would also perfectly describe what kind of texture quality you're going to get with the 8 GB VRAM.
MrTeal
3,919
2,708
In some cases I get the early pushback, where there might be cases highlighted where an 8GB card is getting single digits at 4K in some game and a 16GB competitor is running low 20s. Yeah, 200% faster but neither are really playable.
There are so many examples like this now where the large buffer cards are getting perfectly playable framerates at default settings while the 8GB cards are falling apart. That isn't even a crazy situation, it's 4k but with performance upscaling and very high settings. It's not even playable at 1440p/DLSS-P/VH. Maybe you can go through on a per game basis and tweak individual settings to get the best possible experience, but are the people who are blindly buying 8GB GPUs also the ones who are getting that deep into the weeds? They're just going to turn it down to high and then medium until they find something that doesn't make the game a stuttery mess.
Best part of that screenshot is the power draw. 8GB is holding the 5060 Ti back so much it's pulling 60-70W. Nvidia's crappy choices turned the 5060 Ti into a slot powered 5050.
Ranulf
2,882
2,543
Last of us 2 at 1440p, note the 1% lows:
Screenshot 2025-05-06 at 11-16-02 RTX 5060 Ti 8GB Even Slower Than The Arc B580! - YouTube.png
69fps for the Arc b580 12gb vs 27 for the 5060ti 8gb. But hey, I guess its just HUB being crazy wrong conspiracy dude or something. Its 2025, and your 1440p cards are not the entry level stuff but the mid range $500+ cards. With upscaling AI tech.
I tend to hate the cliche "gaming is dead" meme over the last 20 years but with the price hikes across the board for software and hardware, the industry is not helping itself. They'll just blame tariffs too.
Edit: Hahah, it gets worse. Now Steve gives us, the peasant resolution perf at 1080p:
Screenshot 2025-05-06 at 11-41-34 RTX 5060 Ti 8GB Even Slower Than The Arc B580! - YouTube10fps.png
DAPUNISHER
32,121
32,697
I know you don't like video content so I'll catch you up. He did. He used FSR with the B580 for consistency but I'd have preferred he used XeSS. The stated reason was that the quality setting does not match the other 2 on res, but I think ultra quality does. I am not certain if every game tested includes it though. Regardless, it didn't save the 8GB. Even when it was performing alright, it was mostly failing to be even close to as fast as the 16GB version.
There was a high CPU usage issue too. Steve speculated it might be due to the CPU memory controller getting worked hard trying to swap assets in and out of system ram causing it.
I think he liked the Computer Base testing, he mentioned he might do content on PCIe speed impact next. Battle Mage can suffer from reduced bandwidth in some titles too, so I hope he includes it.
He was also clear some results were strictly for science as both cards failed to provide a playable experience. He mentioned the 16GB version of the 4060 tie sells used for an average of 40% more than the 8GB and thinks it will be worse yet for the 5060 tie in 2-3 years, which I think most of us also concluded.
Thunder 57
4,133
6,890
It's not I don't like video content I just hadn't had a chance to view it yet. As long as it provides good information without taking up too much time I am fine with that. HWUB is right up there with GN IMO. Thanks for the TL;DW though.
EDIT
Also, I tend to not watch most videos until the end of the day.
Rigg
715
1,809
LOL they locked the thread. The new HUB video was about to be a bunker buster, and they can't have that. 🤣
They locked it last night.
PFFT! Who cares about HUB's data anyway! Steve is a biased sellout deliberately spreading misinformation. He's not even using the correct settings!!! I'll wait for a respected reviewer like JayzTwoCents to weigh in. /s
marees
1,973
2,605
Benchmarks​
The Last of Us Part II​
1080p Native, Very High Preset
At native 1080p using the very high preset, the 8GB 5060 Ti performed poorly, while the B580 ran smoothly. The B580 was 12% faster on average and an astonishing 540% faster for the 1% lows. This likely previews how these GPUs will compare in a few years, even at 1080p with reduced quality settings.
Final Fantasy 16​
1440p Upscaling Q, Ultra Preset
Enabling quality upscaling at 1440p drastically improved the B580's performance, delivering around 60 fps and surpassing the 8GB 5060 Ti by 46% – a margin that should never have been possible given the hardware tiers.
Horizon Forbidden West​
1440p Upscaling Q, Very High Preset
the B580 averaged 68 fps – a 152% increase in average frame rate and 241% improvement in 1% lows over the 5060 Ti.
At native 1080p, the B580 maintained a significant lead, offering almost 70% better 1% lows and a smoother experience overall.
1440p Upscaling Q, High Preset
the B580 delivered 76 fps on average and 62 fps for 1% lows, beating the 5060 Ti by 85% and 130%, respectively.
Cyberpunk 2077​
1440p Upscaling Q, Ray Tracing: Medium
The B580 provided a smoother experience with 1% lows 87% higher than the 5060 Ti, which was essentially unplayable.
adroc_thurston
7,641
10,390
Benchmarks​
Final Fantasy 16​
Cyberpunk 2077​
like yeah 1440p gonna nuke 8GB GPUs.
But I don't think any 8G SKU is marketed for 1440p gameplay.
Reactions: reb0rn
Status
