Page 140 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
BFG10K
22,709
3,005
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
TESKATLIPOKA
2,696
3,260
At $400+ just to get more than 8 GB it's hardly worth buying a discrete card. If AMD had desktop Strix Halo class APUs available you could get something with a similar (or greater) shader count as a 9060 XT and as much RAM as you want to put in the system.
Obviously it's not the same RDNA 4 cores and bandwidth will be a concern for any APU, but AMD can definitely make something to replace this part of the market and may as well if it's going to be mediocre at best parts for far more money than they're worth.
1. 9060XT 16GB will be much faster than Strix Halo's IGP despite 32CU vs 40CU and will have the better architecture.
2a. Strix Halo uses LPDDR5X, so you need a board with soldered memory, which of course can't be later expanded.
2b. or If It supports DIMM DDR5, then you still need 4 modules for Quad-channel and 4x module kits are a lot more expensive, unless you want to try your luck with a pair of 2 module kits.
3. New board, don't think It will be pin compatible with AM5
4. For the strongest iGP you will likely need the 16C32T version and that won't be cheaper than R9 9950X sold for 635 €, while for 9060XT you can go with 9700X sold for 328 €, just this alone saves you >300 €.
Yeah, you can argue that 8C16T vs 16C32T, but honestly for gaming that makes no difference.
So in the end, 9700X+9060XT look like a better choice, unless AMD is willing to drop the price.
MrTeal
3,919
2,708
Probably not socketed since AMD is unlikely to develop a new large socket for it, but there's nothing (that I know of) precluding someone like Minisforum putting a Strix Halo on a Mini-ITX or mATX board like they do with the Ryzen laptop chips, and including two LPCAMMs for 256-bit memory.
TESKATLIPOKA
2,696
3,260
But that wouldn't be DIY. But yeah, some already showed Strix Halo in mini PCs.
Iron Woode
31,320
12,833
I am thinking that this poster is psolord in disguise:
But those are Max/Ultra settings. Turn some settings down and the problems go away instantly. Tada...
The answer is that the big picture is lost on some people. You have literal proof in this review that this 8GB card is still a good performer and you're still failing to see the forest for the trees.
DAPUNISHER
32,113
32,682
If after reading the TPU review you were left with the impression he is shilling, just you wait for the AMD 8GB review. He is going to make a big deal out of how 8GB is not the problem, AMD's poor memory management is. He'll repeatedly glaze Nvidia for theirs, in teh process. His testing is poor to begin with i.e. testing in undemanding areas of some games, 25 second passes, still photo comparisons of IQ, shilling for only one vendor in the conclusions, basically everything wrong with traditional reviews.
Thunder 57
4,130
6,886
I always loved Jarred Waltons "8GB of Nvidia VRAM is equal to 10GB of AMD VRAM". Now that's shilling to the next level.
Rigg
715
1,809
That's both right and wrong. While there may be only 4 or 5 defending it, they comprise a significant percentage of the participants active in the discussion. IMO 4 is 4 too many. ;)
EDIT: This discussion gets worse with every page - https://www.techpowerup.com/forums/threads/5060-ti-8gb-doa.335762/
Now combine it with the defenders here - https://www.techpowerup.com/forums/threads/are-the-8-gb-cards-worth-it.335819/
Gotta love our old pal JustBenching entering the chat. Looks like he's branching out from his intel shilling here into a side gig for shilling for NVIDIA on the TPU forums. Wizard's comments in the review thread and DOA thread are straight out of the @psolord handbook. :tearsofjoy:
Thunder 57
4,130
6,886
I read the review thread and some of the comments were just insane. I haven't bothered with the DOA one and probably won't. People will believe what they want to believe.
Rigg
715
1,809
Yup. At a certain point you just have to assume people are either arguing in bad faith because of brand loyalty, because they're trolls, or because they're stealth marketers. Aussie Steve's 5060 8GB video is pretty definitive in my view.
DAPUNISHER
32,113
32,682
I have dubbed him justuserbenchmarking. I am just stoked he posts there and seems happy. I was getting tired of playing whack-a- troll/shill. Has to be a userbenchmark acolyte.
There are some really knowledgeable and helpful folks there, it's a shame the 💩posters are allowed to smear crap everywhere.
Thunder 57
4,130
6,886
I think it's mostly brand loyalty with a good bit of bad faith mixed in. Trolls are everywhere but usually pretty easy to spot.
Rigg
715
1,809
Lol. That's good. Simple (and perhaps obvious) yet clever. Why didn't I think of that? What a 🤡
I only read the review threads over there on occasion. They could definitely use some more active moderation in the forum. Watching Wizard do bench-marketing for NVIDIA kind of makes me want to avoid TPU all together.
TESKATLIPOKA
2,696
3,260
It's DIY other than the CPU being soldered. You'd still get to choose every other part other than the CPU/MB combo.
Only If you can buy CPU+MB+RAM combo. If It's already a built mini PC like what we see so far, then that's no different than a laptop, so clearly not a DIY.
TESKATLIPOKA
2,696
3,260
I don't mind If there is 8GB card, but price should be adequate to It <$300. 5060Ti 8GB is honestly too expensive.
I expect AMD will release both 8GB and 16GB version of RX 9060XT. Yeah, they will be criticized for It, but we don't have 24Gbit modules, so they have to use the same number of modules as they do with RX 9070(XT).
marees
1,968
2,596
Hopefully they rebadge the 8gb version as 9050xt & sell it for less than $280
Reactions: TESKATLIPOKA
Timorous
1,979
3,866
They can cut the bus to 96bit and use 6 modules for 12GB. Slower on average than a 128bit 8GB part but won't fall over in the games where 8GB is too little.
Reactions: Tlh97 and marees
Timorous
1,979
3,866
Yes, it is guaranteed to be slower on average but atleast you don't have to play the game of 'tweaking' the settings
It will be slower except when it isn't and then it will be faster by a lot or it won't load garbage textures.
Also since these parts have x8 PCIe busses the Vram limitation hurts a lot more, especially on older motherboards with PCIe3 ports.
A 12GB 96bit part is a far far far better compromise in the $250 price range and NV had every opportunity to make the 5060 12GB as with GDDR7 even a 96bit bus it is still a big bandwidth upgrade over the 4060 so it would pretty much always be compute limited.
jpiniero
16,939
7,355
Psst, it's not going to be $250.
Reactions: Mopetar
TESKATLIPOKA
2,696
3,260
If It doesn't have enough performance then you will need to do some tweaking, but at least texture quality won't need to be reduced.
I wonder If Nvidia is planning to introduce Super models with 24Gbit modules for every chip.
It would look like this ->
RTX 5060 8GB -> 12GB
RTX 5060Ti 8GB/16GB -> 12GB
RTX 5070 12GB -> 18GB
RTX 5070 Ti 16GB -> 24GB
RTX 5080 16GB -> 24GB
RTX 5090 32GB -> 48GB
But 5060Ti and 5080 are already fully enabled, so the only option is higher TDP and with It clocks.
MrTeal
3,919
2,708
Why would you need to buy the RAM as a combo? The whole idea is that you can choose the amount that's right for you.
You'd just get the CPU soldered onto the MB, but you could still have upgradable RAM, PCIe/m.2/SATA slots, ATX power, etc. CAMM availability is obviously terrible now, but that could change.
Status
