Page 128 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
BFG10K
22,709
3,005
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
MrTeal
3,919
2,708
100%. I expect the 5060 Ti to be 8 GB too, although they might offer a 12 GB option when the 3 GB chips come out.
8GB 5060 Ti would be a joke. Names can be whatever they want, but a card with 4070 like performance or better saddled with only 8GB is absolutely going to be crapping the bed in the next couple years in games it should just blow through.
Nvidia is stingy, but that's almost a step too far.
blckgrffn
9,687
4,348
www.teamjuchems.com
I don’t disagree, but step into r/pcmr and the copium is sooooo strong. A 8 GB 5060 Ti is so weird - it’s going to validate them! If Nvidia sells it, how can it be wrong?!?
And yeah, just reference the OP for all the arguments being made.
I particularly like the “my 3070 Ti runs all games at ultra settings on 1440p so it’s fine for Nvidia to release new 60 series cards with 8 GB” type justifications 😂
Oh well. I expect Nvidia to profit and for next gen budget cards to age poorly. All according to plan! 💩
jpiniero
16,989
7,392
128-bit is 128-bit. The only options really would be to wait until 3 GB chips become available; or use GB205 instead, which doesn't make any sense since yields should be so good to not need that deep of a cut.
DAPUNISHER
32,206
32,852
SteveGrabowski
9,079
7,798
Watch it have 3060 Ti performance like the 4060 Ti did :tearsofjoy:
mikeymikec
21,260
16,501
I wondered if the purpose of the 5050 was to be NVIDIA's only low-profile offering, but then I spotted a low-profile 4060 with three fans and an 8-pin connector:
I wonder how many SFF PCs that would actually fit in, let alone the power requirement.
MrTeal
3,919
2,708
Probably most of them, if you own a soldering iron and a dremel.
Most speculation I've seen has the 5060 using the full 4608 core GB206 or close to it, and it should already be faster than a 4060 Ti. The 5060 Ti would have to slot in somewhere between that and the 6400 core 5070 and be based on GB205/192bit.
If 5060 Ti is 4608 core GB206 128bit and the 5060 is a cut version of that, there's not point in reviewing anything from Nvidia below the $500 price point.
Reactions: Tlh97 and Ranulf
jpiniero
16,989
7,392
Yields are so good at TSMC that it shouldn't be necessary to go that deep even on GB205 (which should be decently smaller than AD104). Mobile parts would be more than enough to handle what would be needed.
You could argue that they should just wait until 3 GB chips arrive to release the 5060 Ti to offer both 8 and 12 (so they can do the same thing they did with 4060 Ti, and people mostly bought the 8 GB model anyway)
blckgrffn
9,687
4,348
www.teamjuchems.com
Ha, or that the 5060Ti should have always been 192 bit from the jump, even with essentially no other die changes. But distinct lack of market pressure means - why? Anyone wanting that can buy a 5070 at launch.
jpiniero
16,989
7,392
The FF7 Rebirth specs say "12 GB recommended if a 4K monitor is used" even for 1080p minimum which doesn't make sense so perhaps a typo.
Does also specifically say that DX12U is required so no GTX/RX 5000 series.
Reactions: Ranulf
blckgrffn
9,687
4,348
www.teamjuchems.com
That’s more interesting to me than the Indiana Jones situation as this is a critical bridge title to a third installment whose sales performance is a really big deal.
Additionally, this also “underperformed” on the PS5 so you’d think the PC sales numbers would be really important.
On the flip side I can see this as Square not wanting to majorly compromise their artistic vision and/or overspend on making it work on the lowest common denominator.
Finally, I loved this game but paused it because it’s soooo much game. Then I thought I’d get a PS5 pro to enjoy it the best possible way and then Sony priced me out of that for now. By the time I get back to it I’ll have forgotten everything 😂
SteveGrabowski
9,079
7,798
Maybe needed for using FSR/DLSS/XeSS to upscale 1080p to 4k instead of rendering straight 1080p and letting the monitor do the upscale? For example I was surprised at how much worse TLOU Part I ran on my 6700 XT using FSR from 1440p to 4k while it ran great just rendering 1440p and letting the monitor upscale to 4k. FSR usually runs a lot better for me. Maybe the upscaling isn't very optimized here either?
DAPUNISHER
32,206
32,852
ROFLwaffles there is no way it is going to be playable on a i3 8100. Windows update alone kneecaps that old quad core. And it's suppose to handle all of the game logic, bloated windows, and stream assets from the required SSD? Good luck with that.
Reactions: Tlh97 and Mopetar
blckgrffn
9,687
4,348
www.teamjuchems.com
Ouch 1080p medium the recommended for my 6700 XT. Guess this won't be much better than playing it on my PS5 Scrub Version Console.
The amount of graphics muscle is almost the same, close enough for hand grenades anyway.
It says it uses Shader Model 6.6 as a baseline, I don't know what that means exactly but it might also be the, oh I forget, the Primitive/Mesh Shaders bit too.
I think the 1400 and the 8100 are both ill equipped for the job, but it appears that's all they'll put there name on to run it. I mean, if an 8100 why not a i5 6570? :D Just for those that enjoy suffering :D
SteveGrabowski
9,079
7,798
Ugh I just read FFVII Rebirth uses nearest neighbor upscaling in performance mode on base PS5 JFC. Between the RX 6700 XT being 15% faster than the RX 6700 that closely matches the PS5 gpu, me being willing to target a 17% lower framerate (50 fps) on PC thanks to FreeSync, and forcing RSR upscaling maybe there is hope of it being better on PC? Can't believe they're just using nearest neighbor. Guessing there will be no FSR since they never put it in the base PS5 version. Of course I say this as someone who bought the game at launch on PS5 and still has it sitting on the system, installed and never played. :tearsofjoy:
Reactions: Tlh97 and blckgrffn
DAPUNISHER
32,206
32,852
Sometimes extra threads are more important than better single thread performance. Testing an FX 8350 and Ryzen 3200 in Witcher 3 Novigrad during a busy time of day around the market and docks, the FX provided smooth frame pacing when the 3200 had notable drops in a few spots. 1400 has SMT which might make the 30fps a playable 30 as opposed to a quad core. Nit picking aside: Fully agree no one should be playing on either, and you can find faster Ryzens for pocket change to replace that OG 4/8.
SteveGrabowski
9,079
7,798
The extra threads on my 4C/8T Xeon E3-1231v3 really came through in the clutch last half of last console gen where I saw people with 4C/4T i5-4690k OC'ed balls to the wall complaining about not hitting 60 fps in games that ran great for me. Figured they would since parallelizing across 8 threads was critical last gen with how weak the IPC of the (effectively) octacore Jaguar cores in the consoles was.
Status
