Page 125 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
BFG10K
22,709
3,005
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
DAPUNISHER
32,184
32,801
16 Series is 5 years old at this point.
Forced obsolescence is forced. Worst part is it'll work. They have done it, they have an Apple style cult.
Any self respecting GTX owner would buy Intel or AMD next time - but the power of the green kool aid could not be undone. They have gotten the 🖕from Nv on upscaling and frame generation, now they can add Nvidia sponsored games to the list? The devoted must buy a new RTX card or be ex communicated. 👻
jpiniero
16,983
7,383
The consoles have it, that's why. I remember when people complained about a console port being AVX only long after the PS4/XBO had been released.
DAPUNISHER
32,184
32,801
False equivalence.
marees
2,002
2,630
Hub Voters about 8gb price
Only b580 available within that max budget ($250) with > 8gb
The 3060, 6750 xt & 6800 will soon go out of stock
The 7700xt has occasionally sold for $350
So from AMD side you need atleast $350
As of today from Nvidia side atleast $450
poke01
4,553
5,847
Ouch, it's not just 8GB. Now 10GB isn't enough either. 12GB RX 6700 XT beating the RTX 3080 by nearly 90% with RT on in a game I want to play. Very happy I went AMD.
By the looks of it in 2 years 12 GB won’t be enough and then in 4 years 16GB won’t be enough. PS6 generation will probably will 24GB VRAM.
Perfectly good GPUs wasted by low VRAM.
SteveGrabowski
9,074
7,796
Thankfully my 6700 XT looks like it was given the correct amount of VRAM. Still aging pretty decently nearly four years later. I figure I'm going to have to ride it into the ground before finding another card worth buying with the way Trump's tariffs are going to skullf--k gamers.
blckgrffn
9,687
4,348
www.teamjuchems.com
10 was always weird, and 20 is weird now. 10GB saving grace was likely the 10GB fast pool on the Series X but since Xbox games have to support the series S, I guess they might just tune for that and call it a day.
Just saying if there isn’t a big enough install base, no one will tune a profile to it. 8, 12, 16. Those must be the targets. And likely a “low” that’s a catch all for below that. 12 should last for a lot longer due to the massive and still growing install base.
SolidQ
1,526
2,504
Same was with PS4. Console have 8GB, on PC you need 16 RAM and 8 Vram. If PS6 will have 32 GB, you need 32VRAM, and 64GB ram
Reactions: Tlh97 and Tup3x
Tup3x
1,282
1,414
You know, for this reason beefy APU with 64GB would be rather interesting. You'd never have VRAM issues. High end cards should be 24GB minimum because 16GB cards will have issues if next gen consoles have 24-32 GB of (shared) RAM. Even in that case maxed out PC settings might hit the 24GB limit.
MrTeal
3,919
2,708
Sad 3080 noises.
I wondered at the time I sold my last 6800 XT if I should have kept that rather than the 3080, but running custom loop and not wanting to buy another block really tilted the choice.
Reactions: Tlh97 and blckgrffn
Mopetar
8,510
7,766
The consoles are essentially already using something akin to Strix Halo. Both Sony and Microsoft have APUs that dedicate a lot of space to the GPU.
The console manufacturers could include more memory in their systems, but to keep costs down they're always going to have less than may otherwise be ideal.
I wonder more if they'll consider trying to implement v-cache in some form, especially if the newer techniques to use it are less expensive or more available. Having a fat SLC under a 300 mm^2 APU would alleviate a lot of pressure on the memory bus and save on having to use more expensive memory types to get the desired performance.
Having 32 GB of memory doesn't do much if you have to squeeze it through a slow and narrow bus.
blckgrffn
9,687
4,348
www.teamjuchems.com
Sad 3080 noises.
Very understandable.
Is there a 3080 12GB or 3080 Ti you could sneak in there with minimal effort? Maybe worth it to squeeze a couple more years out of the loop.
blckgrffn
9,687
4,348
www.teamjuchems.com
I guess we'll see what happens, but I expect a 2x increase in the amount of memory in the next consoles, up to 32GB. This will allow them to allocate ~24GB to the GPU and honestly, the memory amount seems to me the "easiest" lever they have left. CPU performance headroom is going to be somewhat limited without a 3D cache setup and even then, the road to 100% uptick in CPU performance without going wider (ie, 10-12 cores) seems murky to me. On the GPU side, I think its even grimmer if the PS5 Pro is the new benchmark. Another 50% increase is going to be quickly swallowed by software and another small step towards true 4k rendering.
This is even at PS5 Pro power consumption levels, which I am not sure is a given. A ~32MB infinity cache would make a huge difference to bandwidth and they can probably use some relatively high density memory and it might be a wash on the cost vs the current memory in the PS5 given the volume in which Sony can purchase.
The easiest way for the next gen consoles to differentiate themselves is through more memory for more higher res textures. 24GB would be a relatively small jump.
My $.02.
MrTeal
3,919
2,708
3080 Ti no, but 3080 12GB or 3090 yes as long as it's a FTW3. I've been keeping an eye out, but the 12GB never really sold well and people at least in my smallish market still seem to want CAD1000/US$700 for their used 3090.
Reactions: blckgrffn
Status
