Status
Not open for further replies.
BFG10K
22,709
3,007
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
jpiniero
17,165
7,543
They just might. They know that the low VRAM is making them look pretty bad in benchmarks and now they get to charge possibly up to $100 more for the highest VRAM configuration. But that will be MSRP. Actual prices will be crazy high for the 16GB one.
I think this is just a case where Gigabyte has no idea what nVidia is planning and just made up 10,12,16 GB SKUs. A theoretical 16 GB model would be 128-bit with the clamshell or 4 GB chips.
TESKATLIPOKA
2,696
3,260
There is also a strong belief on my part that GPU manufacturers overly influence developers to make their games as difficult to run as possible and that includes going extra heavy on the vram, even when not necessary. Its the way they stay in business.
AD106, AD107 have only 8GB Vram and AD104 12GB, so I don't think influencing game developers to increase Vram usage is what Nvidia does. If they want to stay in business, then they would influence them to use less Vram.
Reactions: Tlh97 and scineram
GodisanAtheist
8,503
9,933
- While to don't entirely buy into the base theory, NV has shown itself absolutely willing to screw over its own customers if it means screwing over AMD more.
However, given AMD tends to have the VRAM advantage per tier (at least for the last gen) I can definitely see this as a play on their part (they even did it with Farcry 6's high res texture pack).
Heartbreaker
5,310
6,997
No I dont believe its "a lie". Just that other sites report no such issue, but rather smooth or "fluent" gameplay at the same settings.
There is definitely something odd going on that HWUB/Techspot should have noticed about the FC6 results:
October 8, 2021
The FC6 GPU test, Ultra 4K HD texture results:
Cards of interest:
6800 57/64
3070 Ti 51/60
3070 45/56
6700 XT 42/49
So initially, 3070, has no issues at all at 4K Ultra/HD textures, then:
March 22, 2022
The 3070 vs 6700 XT test, FC6 , High 4K HD texture results:
3070 9/44
6700 XT 56/63
Now the 3070 is completely crushed, but further into the future a 3070 Ti vs 6800 comparison:
October 17, 2022
Unfortunately we don't have detailed results for Far Cry this time, and just the Percentage difference (3070 Ti 10% slower than 6800). But I think that's enough to see that 3070 Ti (also with 8GB) is NOT being crushed here...
Back when the 3070 tested against 6700 XT, 6700XT wins FC 6 by over 40% when 3070 wins 4K overall by something like 20%...
But the 3070 Ti is a bit slower overall vs 6800, and only loses FC 6 by 10%...
It really looks like the March results were some kind of anomaly.
Stuka87
6,240
2,559
I picked up Hogwarts Legacy yesterday. And I am unable to play the game at max settings, even with FSR enabled (equivalent to 960P) because I run out of VRAM with my 5700 XT. The game runs smooth from a GPU point of view, but if you hit a new area its stutter city.
If I drop the settings to "high", the stutter goes away completely. VRAM usage averages around 7.5 to 7.8GB on High.
jpiniero
17,165
7,543
Really need more games with DirectStorage to see how well developers can leverage it.
BFG10K
22,709
3,007
They're testing different parts of the game, just like how Howarts Legacy isn't VRAM limited in every area. This is really quite elementary.
Ubisoft clearly lists the requirements: https://www.ubisoft.com/en-us/help/...g-the-hd-texture-pack-for-far-cry-6/000099142
Please note that the minimum requirement for running the HD Texture Pack for Far Cry 6 is 12GB of VRAM. For 4K configurations, you will need 16GB of VRAM.
If you download and run the HD Texture Pack with lower VRAM capabilities, you will encounter performance issues while playing.
The stuttering has been confirmed by a plethora of people including HWUB. If you think HWUB, Ubisoft and all those people are lying, you need to provide evidence.
LMFAO. That's a new one so let's add it to the list:
Reasons why 8GB nine years after first release isn't nVidia's fault.
  10. 4K is irrelevant.
  11. Texture quality is irrelevant as long as it matches a console's.
  12. Detail levels are irrelevant as long as they match a console's.
  13. There's no reason a game should use more than 640K 8GB, because a forum user said so.
  14. It's completely acceptable for 3070/3070TI/3080 owners to turn down texture settings while 3060 users have no issue.
  15. It's an anomaly - guidryp (2023)
If you have any other reasons why 8GB isn't nVidia's fault, please let me know and I'll add them to the list. Cheers!
Borealis7
2,901
205
DRAM prices went up for 3 straight years (Samsung/Micron/SK Hynix...)
Heartbreaker
5,310
6,997
Don't put words in my mouth. I never said they were lying. I just said something was odd, that HWUB should have noticed.
For 8GB cards:
Oct 2021: No problem with HD textures at any resolution, including 4K.
Mar 2022: Big problem at 4K (none at 1440P)
Oct 2022: No problem at 4K again...
It's something that bears a little more investigation.
Even if this was the consistent result for Far Cry. It's hardly a big deal. You could simply use DLSS/FSR for that game, if you want to run 4K on a mid series card like the 3070...
amenx
4,676
2,983
I think its become clear that 8gb (midrange) GPUs are not capable of running modern games at 4k resolutions at ultra++ settings. Any folks here or anywhere that use their 8gb cards under such scenarios? And not aware of higher tier GPU options designed for those conditions?
Of course there are also many games at 4k that run well at decent settings with 8gb cards (just dont go overboard).
So focus should really be on 1440p and 1080 since these are the most likely resolutions utilized by 8gb GPU owners. 2 years ago (at start of this thread) this was not an issue other than an isolated example here or there being run at some crazy setting (despite still finding the odd contradictions to some of those examples). Yes, the vram is holding you back despite getting over 100 fps. :D
But for newer games today at 1440p being played with older 8gb GPUs, the GPU manufacturers message is loud and clear, that you must upgrade your cards....... Or ignore them for another year or two and continue to enjoy the vast majority of games @ 1440p that have not yet been hampered by the lack of vram.
Stuka87
6,240
2,559
I can't even play Hogwarts Legacy at 1440 though. I am running out with it at 960P (FSR Quality with 1440 native) with the settings on High, not Ultra.
Reactions: KompuKare
Stuka87
6,240
2,559
For 8GB cards:
HWUB likely tested a different area because there were threads on forums/redit of people having issues. The vast majority of testers only test some place at the start of the game.
Reactions: Mopetar
amenx
4,676
2,983
More HUB inconsistencies. Look at HUB review of Hogwarts Legacy vs their Techspot review. Again, same reviewer, same settings, same results, except the 3080 10gb. It scores higher in his Techspot review.
HUB Hogwarts Legacy - 1440p (Ultra quality) TAA high, Ray tracing ultra
Techspot Hogwarts Legacy - 1440p (Ultra quality) TAA high, Ray tracing ultra
Heartbreaker
5,310
6,997
Or differences between game patches and/or driver updates. We just don't know what happened because there was one anomalous result out of three tests, that wasn't investigated/explained.
amenx
4,676
2,983
Thats because the benchmark that is built into the game doesn't represent game play in areas that have the issue. It also gets worse the longer you play. The benchmark doesn't replicate this.
Sounds like sloppy memory management by the game engine in allowing assets to accumulate without purging them.
SteveGrabowski
9,352
8,032
Bad PC ports are the rule and not the exception though. Needing to go overboard on hardware being a necessity for AAA PC gaming has been a general rule for at least this century.
Stuka87
6,240
2,559
Unreal engine is the most used engine in gaming. Pretty sure they have memory management figured out.
Status
