Page 101 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
BFG10K
22,709
3,007
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
Mopetar
8,534
7,799
HUB has a new video out showing how much VRAM games utilize at various resolutions and performance settings. It covers a lot of the same titles that have already been discussed in this thread, but I thought it was interesting.
poke01
4,920
6,268
Yep, do NOT buy a 8GB VRAM card in 2024. 12GB is bare minimum and 16GB is ideal.
poke01
4,920
6,268
Iron Woode
31,397
12,872
Well, he convinced me! 8 GB cards? Nah, I am now running my old GTX 1060 3GB card for 4K gaming at the "correct settings".
Never mind that the "correct settings" is 1024 x 768 upscaled with everything set to low but hey, getting 6FPS is obviously so worth it.
Thunder 57
4,304
7,113
I've read 640x480 upscaled works better because it was the original VGA resolution. You might get some more frames out of that.
Ranulf
2,921
2,602
Heh, I wish I still had a good CRT monitor at 1280x1024 res or so. It would be great for older games especially. If only LCD tech could scale as well as CRT did.
Thunder 57
4,304
7,113
That's one thing I miss about CRT's. Options. I ran 1152x864 as my standard for awhile. But I could always go a bit higher or lower if necessary. Their massive weight though, I do not miss that at all! EDIT: Didn't they fix that with Integer Scaling?
Reactions: TESKATLIPOKA
19,219
In terms of quality, OLED reminds me more of CRT, maybe coz CRTs were also good at searing retinas with actual electrons fired at the phosphor dots :S
coercitiv
7,518
17,987
The part that is harder to fix (as in emulate) is the inherent properties of CRT. Due to the way it works, one could argue it has both black frame insertion and frame generation baked in. :cool:
Mopetar
8,534
7,799
I remember getting a 17" CRT and thinking that I was king of the world. One could argue that given the weight it still might be useful to this day as gym equipment. That thing was a beast.
Had anyone actually tried out frame generation with a sub 720p resolution? I'm kind of curious if only just for a good laugh at what it might spit out. If it's nightmarish enough, someone could even design a game around it.
Iron Woode
31,397
12,872
I had a 20" Sony CRT and that was one heavy monitor. It used BNC connectors.
DAPUNISHER
32,477
33,533
The Spiderman Remastered testing in the OP by some Youtube rando is okay but leaves something to be desired. Showing system ram usage for starters. This morning my allocated was more than twice the used amount. The vid shows a 3-4GB increase for the 8GB 4060ti but seeing the usage would have been more revealing. The 8GB may have been using almost all of it, while the 16GB may have been using half or less of what was allocated.
Running down the street in a not particularly crowded area is not stressful enough. Anyone with 10s of kilometers of "skimmer" knows that swinging near street level in busy areas like Broadway taxes the system from the amount of asset streaming.
Last gen RX 6800 in Horizon:FW expansion's toughest area doing 4K high + FSR Q+FG with impressive results. Using more vram than the 4060ti 8GB has to give.
marees
2,348
2,953
Text version (for 4060 ti 8gb vs 16gb)
with the exception of entry-level options, you shouldn't be buying 8GB graphics cards anymore. 12GB is now the bare minimum, and 16GB is the ideal target.
https://www.techspot.com/review/2856-how-much-vram-pc-gaming/
What Does Running Out of VRAM Look Like?​
  1. Halo Infinite —​
    • ultra preset with ray tracing enabled is out of the question, as it uses 10.3GB at 1080p and 11GB at 4K
  2. Forspoken​
    • Upon release, Forspoken would miss all textures without enough VRAM, resulting in a horrible-looking game.
    • Now, it removes textures for everything not currently in view and tries to load them where they are most obvious. This results in texture pop-in and sometimes texture cycling, where high-quality textures appear and disappear, (as we've also observed in Hogwarts Legacy. )
  3. Ratchet & Clank: Rift Apart —​
    • It is possible to use the very high setting at 1080p on an 8GB GPU, but you will likely notice some frame time issues, and it's unlikely that all textures will be rendered at full quality. Enabling ray tracing with the very high preset won't end well, as this uses 11.2GB of VRAM. If you enable frame generation, it will push you over 12GB.
  4. Cyberpunk 2077: Phantom Liberty —​
    • Problems start to occur for 8GB graphics cards when enabling ray tracing, which pushes memory usage to 11GB at 1080p and 12GB at 1440p. If you enable frame generation as well, you're looking at 12GB of usage at 1080p, 13.5GB at 1440p, and 16.5GB at 4K.
  5. Forza Motorsport —​
    • ultra preset with ray tracing enabled is out of the question, though, as it uses 10.3GB at 1080p and 11GB at 4K
  6. The Last of Us Part 1 —​
    • Even after several optimization patches, the game still requires more than 8GB of VRAM at 1080p if you wish to use the 'ultra' preset.
  7. Avatar: Frontiers of Pandora —​
    • A quick in-game comparison between the 8GB and 16GB versions of the RTX 4060 Ti at 1440p using the ultra preset showed the 16GB model delivering 25% higher 1% lows.
  8. Homeworld 3 —​
    • Those playing Homeworld 3 with an 8GB graphics card should avoid the 'epic' quality preset and instead stick to 'high' as the maximum setting. Though 'high' does result in noticeable frame time performance, we recommend 'medium' as this will keep you within an 8GB buffer, even at 1440p.
  9. Hogwarts Legacy —​
    • 8GB graphics cards are limited to the 'high' preset without any ray tracing at 1080p and 1440p. Enabling the 'ultra' preset will result in either missing textures or poor frame time performance.
  10. Starfield — not memory-hungry, until 4K​
  11. Horizon: Forbidden West —​
    • In Horizon Forbidden West, in some in-game cutscenes, the 16GB model was up to 35% faster and had fewer frametime spikes, which is more noticeable during gameplay.
    • On average, the 16GB model was 40% faster and offered significantly better frame time performance, resulting in a much smoother and more consistent experience.
    • Even with DLSS upscaling, the 16GB model is much better, offering higher frame rate performance with better frame time consistency. In our tests, we saw the 16GB model achieving 73 fps on average compared to 49 fps for the 8GB model – that's nearly a 50% improvement explained by having the sufficient VRAM capacity.
  12. Senua's Saga: Hellblade 2 —​
    • Senua's Saga: Hellblade II will use more than 8GB of VRAM at 1080p with the 'high' preset and well over that if you want to enable frame generation.
  13. Ghost of Tsushima —​
    • if you enable DLSS frame generation, you might see some issues at 1440p and almost certainly at 4K
  14. Alan Wake 2 —​
    • At 1080p, an 8GB GPU will suffice for the medium and high presets. However, enabling ray tracing will be problematic as this requires over 10GB, so a 12GB VRAM buffer is necessary here
marees
2,348
2,953
  1. Halo Infinite —​
  2. Forspoken​
  8. Homeworld 3 —​
  14. Alan Wake 2 —​
What would be the maximum that you would pay for an 8gb card ?
Assuming gpu size is not the bottleneck, it could be as powerful as a 4080 for example
Current nvidia prices in newegg:
4060 - 300
4060ti - 390
4060ti 16gb - 450
4070 - 550
4070super - 600
MrTeal
3,919
2,708
4060 - 300
4060ti - 390
4060ti 16gb - 450
4070 - 550
4070super - 600
Best Buy Canada had a Zotac 4060 for $310 Canadian pesos yesterday, which is US$228. I think in that price range it's perfectly acceptable to pick an 8GB card.
US$390 for an 8GB 4060 Ti is just out to lunch though.
Mopetar
8,534
7,799
$200 if it's a new card from the latest generation which itself isn't over a year old. Otherwise $150 is where I'd draw the line as moving up to something with 16 GB, even if it costs $300 more, will at least ensure it will be useful in 5 years.
I'd like to see Strix Halo included in some of these tests in the future. It's the first truly top end APU in terms of what it brings to the table with the 40 CU GPU.
Although it's a premium product, it also has to exist in a more limited TDP and doesn't benefit from faster GDDR memory (and further has to split its available bandwidth with the CPU) but I think it will be able to beat these discrete cards in the cases where they hit the 8 GB wall.
We'll probably see a more reasonable mainstream APU with around 24 CU in the near future and those will make 8 GB cards pointless. Even if the card has more shaders, the memory bottleneck will prevent them from being fully utilized.
Mopetar
8,534
7,799
Strix Point has up to 16 CU, and while those no guarantee that AMD increases to 24 CU with their next generation, if they don't the one after definitely will.
I don't think it will be more than 3 years to see some mainstream part that hits those targets.
jpiniero
17,228
7,595
Well... If you think about it, Kraken is the real replacement for Phoenix and that has less CUs. With node costs not getting cheaper and all of Tech obsessing over AI, there's no telling what AMD does with IGPs. The people who want good IGP/low end GPU performance also don't want to pay for it (see above)
Mopetar
8,534
7,799
I think if they had a modular chiplet based solution they could cater to the market. Imagine something similar to their current desktop Zen but with an IO die that can connect to three chiplets, which can be any combination of CPU or GPU cores.
After RDNA3 having issues I'm a little more leery about AMD going down that path anytime soon, but a few years ago it seemed like something they might be aiming at.
Status
