- Jul 26, 2001
- 1,146
- 0
- 76
For running 3 monitors. Can you run the 8800 series and a 7600gt together or do I need to get a non-nvidia card for the 3rd monitor? I'm using Vista btw...
Originally posted by: krotchy
you dont need an identical card for the 3rd/4th from what I understand, however if you went SLI then added another for the 2nd/3rd monitor it has to be ATI I think. This is because SLI doesn't allow more than 1 monitor.
Originally posted by: Skyguy
BUT.............
Assume you're not going SLI.....just 3 monitors over 2 cards.
What do you do about drivers? 8800 drivers are a completely separate download than 7xxx series. So which do you install? How does that work?
