8800GT freeze!
OVerheating: No.. Its Temp ranges between 50-59 Celsius...
OC Gone bad, I havent even tried to OC it yet
PSU, Its a 500W .. I replaced my old one when I got my 8800GT
Sorry to hear it's not an obvious problem, if you want to play it safe, then i recommend you RMA it as error8 told you. It's easy and won't cost anything.
I won't visit this thread again, i already fixed my problem, and posted the solution. Really hope you fix it.
Originally posted by: os008
Well, nobody is so lucky, that means i was doing the right thing, simply because they're ALL stock speed Bios' made for 8800GT cards.
And despite a lot of them not made for reference cards they work, EVEN if one stops the card from working, i could blind flash it. The only way i could ruin the card is if the Bios was actually made for another 'core'.
Again, no-one is that lucky, and besides it's my card, and i do whatever i want with it, or am i wrong? I did NOT, and will NOT, ever recommend such a thing to anyone.
Anyway, as i've said before, the symptoms he's having are the same as mine, i tried everything, from lowering the voltage, increasing it, lowering the clock to lowest possible in RivaTuner, using modded drivers, cooling the card to 50c at max load possible by directing the A/C at it for 15 minutes before even starting any test, changing the timing of the RAM, man, i can't remember what else i tried, EVERYTHING. The only thing that worked for me was that Bios, how do you explain that?
If you're so smart as to criticize anyone just like that, and negate his work, then please explain to me how did i get it to work? (the reason for sarcasm is because you returned to the old explanations despite me telling everyone that non of that was the cause of the problem)
Of course before even trying the Bios i assume you tried everything error8 just told you, that's just logic. If that Bios doesn't work, then RMA it.
In the end, i have to say this ... when i received the email telling me that someone replied to my thread, i said to myself 'don't bother, you solved the problem already', but then my conciousness nagged me and told me ... 'what if someone is in the same trouble as you, RMAing won't work in most cases' (yes, some i know tried that), so, i just followed what my religion tells me ... 'love for others what you love for yourself', guess you have the same saying in your language.
EDIT: to explain the last paragraph, the part about the language ... I'm from Egypt.
You said you did not recommend that , but that's exactly what you've did. Flash your bios as many times as you like , do whatever you like with your card, but please don't recommend that to other people. If you like taking risks do it on your own skin. Different 8800 GTs cards can have different pcbs and who knows what a bios from another card could change at yours, maybe some voltages of some components and other things, that a "blind" update won't bring it back. And don't be sarcastic with me, you're not impressing anyone.
Your case was a clear RMA case, if the bios update worked for you, then congratulation for having the problem fixed, but I think that most people in your situation would have just used the warranty. ( the safest thing to do)
Then I have no idea what else to recommend you. The card seems cool enough, the PSU should be fine, even though is not one of the best, no OC. I guess the last thing you can do is to play it safe and use the warranty and let others break their heads with it, since is pretty clear that something is very wrong.
It was a very good thing if you could have tried the card into another system, just to rule out any other possible problems. But I see you can't do that!?
Wierd thing is this is I already RMAed a 8800GT b4...If I do that again,they're gonna think I mess them up on purpose 😛
Technical Support over here consists of ID-10-Ts..They dont know whats wrong with it...
Also, My kind of error doesnt appearso often, so hard to replicate it for them to c...
While logging using the nTune utility... Ive noticed that the Disk % Spikes up to 98-100% during the glitch..While remain VERY low otherwise... Is that any help??
