Originally posted by: n7
Originally posted by: Patt
Dude, where do you do your shopping, seeing as you're in Edmonton? Do you buy anything local? I live 500 km north, but am still finalizing my specs/prices. Have you bought anything from MemoryExpress by any chance? Cheers.
All over.
www.ncix.com
www.directcanada.com (NCIX.com subsidiary that's usually cheaper)
www.tankguys.biz (US store that's awesome & ships to here)
Locally, i usually hit up:
www.memoryexpress.com
www.a-computers.ca
www.bcom.ab.ca
www.futureshop.ca
Yes, i've purchased a number of things from MemoryExpress, & i actually find them the best store locally by far, except that they never have the stuff i want in stock
That & they basically have a fit if you ask to price match lol...
I'd suggest the Corsair HX520/620 as it's the quietest well reviewed high end PSU out there.
E6600 sounds good; i'd recommend getting it locally, so you can see the steppings, & avoid the new "F" code one.
You want "B" or maybe "A".
E.g, L632
B173
As for RAM, you technically don't need great RAM to achieve great OCs with the E6600 (due to its higher multi), but i'd still prefer it, as it allows for 4:5 or higher speeds unlinked (if you go nF 6xx).
G.Skill "HZ" (should be Micron; not sure what exact IC it is now)
http://www.directcanada.com/products/?s...=F2-6400PHU2-2GBHZ&manufacture=G.SKILL
Team Dark (ProMOS, but clocks well)
http://www.directcanada.com/products/?s...HC4DC-D&manufacture=Team%20Group%20Inc.
Mushkin XP2 (Micron D9GMH)
http://www.directcanada.com/products/?s...0BD7763&vpn=996523&manufacture=MUSHKIN
Team Xtreem 667 & 800 (Micron D9GMH in both)
http://www.directcanada.com/products/?s...HC3DC-M&manufacture=Team%20Group%20Inc.
http://www.directcanada.com/products/?s...00HC4DC&manufacture=Team%20Group%20Inc.
OCZ Reaper 1066
http://www.directcanada.com/products/?s...832&vpn=OCZ2RPR10662GK&manufacture=OCZ
Overkill heatpiped cooling, but cheap for higher binned Micron
OCZ EL Platinum 1000
http://www.memoryexpress.com/index.php?...tDetail.php&DisplayProductID=7854&SID=
Not sure what IC, but assuming you get the rebate back, not badly priced at all
Seriously though, all those links mentioned (all of them are very good for OCing), i'd suggest this:
Generic Micron 667
http://www.memoryexpress.com/index.php?...tDetail.php&DisplayProductID=7873&SID=
Check the ICs; if it says D9GMH, you can score 2 GB of great OCing RAM for $220
