AzN
Banned
- Nov 26, 2001
- 4,112
- 2
- 0
Originally posted by: toyota
high settings for non core2 cpu users? NO. medium settings at 1024x768 is playable until after the core level then its all low for the snow and carrier levels. with a good core2 duo you could probably put most of the settings on high at 1024x768. regardless of what people "think" Crysis is very cpu demanding below 1280x1024.Originally posted by: Piuc2020
Originally posted by: error8
Originally posted by: IL2SturmovikPilot
My HD 2600XT can run Crysis on Medium @ 1280x720 with 20-35FPS.... you are obviously biased against anything below your 8800/HD 3800/whatever you have in performance.Originally posted by: error8
Originally posted by: msi1337
I ended up getting a 8600GT 512MB Gddr3 msi card from Newegg with free Witcher game for $85 after rebate
for me 8600gt is perfectly fine. all my games aren't very demanding. Lots of the reviews at newegg say they can play Crysis with this card with 25-27fps.
Maybe they can play Crysis with it on low settings, using 800X600 resolution.
No I'm not biased, but I really don't think you are having so many frames per second with your card in Crysis. I do own a 8800 GT though, but it always struggled in Crysis on medium, high or whatever. It never played smooth so how could a 2600XT with 256 mb on 128 bits can do the trick?
Your doubts are well-founded but wrong nevertheless. A 8600GT can play Crysis fine at 1024x768 high settings or crank it up to 1280x1024 on medium settings, sure this is averaging around 20-25FPS but Crysis is completely playable at these settings.
I had a 8600gts. It's a little faster than 8600gt. Crysis medium was all that it could muster @ 1440x900. High settings was out of the question unless 800x600. 1024 if you like 15fps average and I was running a core 2 duo @ 3.05ghz.
Crysis is video card limited not CPU limited.
http://www.gamespot.com/features/6182806/p-6.html
IT IS CPU LIMITED AT 1280X1024 OR BELOW. your own link shows that a fast core2 cpu will nearly DOUBLE the framerate over an AMD cpu at 1024x768. below 1280 with my comp I would get a bigger increase in fps by going with a fast core2 cpu than going with a faster card and thats a fact. I used an 8800gt for two weeks and it only made 5 fps difference(from 31 to 36fps) at 1024 over my 8600gt.
That's on a 8800gtx not a 8600gt.
Maybe 3 year old game like Half Life 2 or BF2 on a 8600gt.
Crysis and all modern games are video card limited especially on a 8600gt. Your 8600gt can't even get 30fps @ 1280x1024 with E8400 @ medium. Argue all you like but in the end you have no idea what you are talking about.
