80mm fans everywhere - but thin ones? - n/m
Jeff7
41,596
19
I need to replace some fans in a power supply, but they need to be very thin - 15mm. The thinnest I've found thus far is 25mm. Does anyone know of any good places that have thin and cheap 80mm fans?
Never mind; it's probably just going to be simpler to stick a thicker fan on the outside of the power supply; might have to check that it won't interfere with my CPU cooler though. Globe Fan does make an 80x80x15 ball bearing cooler, but their site doesn't list any distributors.
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,684
Try Gizzo's fan page> fans for sale> down at the bottom he has some 80x15 panaflos- might be more fan than you need, but they're the only ones I know of.....
Jeff7
41,596
19
I've only heard of Gizzo's fan page; no idea where it is though.
Jeff7
41,596
19
Sorry, but have to say it.
:Q
Am not ready to spend $15 for a single case fan; I might just have to stick a standard fan to the outside of the power supply instead.
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,684
I'm with you, $15 is steep. It IS a specialty item, though, hell to find at all. Attaching fans/wire grilles to the outside should work fine.
Have fun.
wasamicron
360
The aluminum hard drive cooler at case-mod has a very thin 80mm fan in it.:) I think it was 7 bucks. Maybe, you could use the fan from it.
Jeff7
41,596
19
I don't think that a HD cooler could move enough air to cool a power supply. I need at least 20CFM.
Thanks for the thought though.
