Originally posted by: ballmode
Would 2 GB of ram increase my score by 1000?
Originally posted by: Skyhanger
eVGA has the geometry clock set 40MHz higher than the rest of the other clocks when you run an 3d App.
At the stock clock speed of 445MHz/1.07GHz, the geometry clock will show as 485MHz.
If you run rivatuner, you can see each individual clock in your GPU card.
Originally posted by: Topweasel
Its not overclocking, their is a geometry engine that is running 40MHz higher then the rest of the core at any speed. If you look at Riva tuner and compare those speeds with what coolbits has set, only on 2d apps does that 40MHz not appear. For Example MSI sells default GTXs only yet thiers will show up as 463 or so. Try to find a single GTX bench mark at 430 I bet you can't find it.
Originally posted by: MoMoJuice
I got 7995 on 3DMark 05, only need 5 more to break 8K.
Not sure why though, I have my 7800GT OC'ed to 485MHz, but 3DMark 05 says I have it at 524...hmm
Anyway, you can check it Here
Originally posted by: aldamon
rahzel, you should download Nibitor and play with the geometric clock increase. I'm using a customized version of the Rev. 2 BIOS with a 30 Mhz delta. I tried a 50 Mhz delta but didn't fare to te well. LOL.
Socket 754 and PCIe does not make sense to me. When did a motherboard for socket 754 who also support PCIe
Originally posted by: omniphil
Wow, those are really good scores... I have a 7800gtx and stock it was 7400, overclocked to 500/1300 its 8300. Those 7800gt's are pretty damn close. Damn, something must be up with my system?
amd 4000+
two 512mb sticks
7800gtx
