lehtv
- Dec 8, 2010
- 11,897
- 74
- 91
I agree, Anandtech's memory scaling comparison confirms that faster RAM is absolutely useless for gaming on SB.I get what your saying but if you use your PC primarily for gaming and don't do compression and video encoding then there really is really no benefit going above 1333MHz IMO
Yes, I could recommend a $200 board to someone who has very high quality and connectivity requirements and a big budget. That's obviously not the only variable though. If you pay $300 for a 2600K or even more for the upcoming SB-E, $60 for a high quality CPU cooler, you only need to spend another $140 on a motherboard to reach $500. Adding 16GB 1333MHz RAM worth $90 will make that a $590 setup. 16GB 1600MHz is only $10 more, increasing the price of your core setup by ~1.6% which is comparable to the performance increase you get in encoding applications. A small increase in price for a small increase in performance - I'm not going to complain if someone makes that choice.also is there a time when you should ever recommend a board over $200? even if he has a big budget it's still money down the drain.
Well, he gives baffling advice like how a 955BE + 6950 2GB is somehow better than a 2500K + 560 Ti 1GB for a $700 build, and now this. I don't even know whether if he is actually using his head to think.
1) That's off topic. If you want to discuss that "baffling advice" why don't you discuss it in the actual thread were the advice was given?
2) You're misrepresenting my position on that matter. There's a lot more to it than "2500K + 560 Ti versus 965BE + 6950 2GB". If you had read my posts in that thread, you'd know this. The 2500K build sacrifices a lot of things that I would prefer not to sacrifice (YMMV) unless the idea is to build an $800 rig, not a $700 rig.
