Originally posted by: Acanthus
Originally posted by: DaveSimmons
The odds of losing your data are doubled when you use RAID0 so be sure to come up with a backup strategy.
If you're doing this to improve gaming performance, click the "Storage" tab at the top of the page and read the article on the real-world performance of Raptors in RAID0.
You dont half the MTBF of the drives by using 2its a fallacy.
Yes, yes you do.
Two drives means twice the chance of failure. Or, in other words, MTBF/n, where N is the number of drives involved on the RAID-0.
3 drives means 1/3rd the MTBF. 4, 1/4th.
FYI for the OP: You might be better off with RAID-1 then RAID-0. RAID-0 only offers benefits in a limited selection of benchmarks and a -handful- of extremely disk intensive consumer uses. I highly doubt you will be dealing with art files in the multiple-gb range and whatnot, so.... However, RAID-1 offers a similar performance benefit when it comes to reads. Plus, a RAID-1 will protect you against failure of a hd.
The MTBF of 1 drive is (made up for the example) 100000 hours. The MTBF of 2 drives is 100000 hours...
Adding another drive doesnt make the 1st or 2nd more likely to fail, while i agree there is a small increase in risk, if the drive dont die within the 1st 2 months... they are going to last a long time.
-sigh-
RAID-1 and RAID-0's MTBFs are incredibly easy to calculate. RAID-1 is MTBF*n, and RAID-0 is MTBF/n.
To quote this "The issue with RAID 0 has always been that splitting data across two hard disks inevitably resulted in doubling the chances of data loss via hard disk failure." MTBF/n, as I said.
And to quote this, "he Mean Time Between Failure (MTBF) of the array will be equal to the MTBF of an individual drive, divided by the number of drives in the array." Again, MTBF/n.
I can find hundreds of more sources easily if you want.
