p8p67 pro
I don't want to move them, haha...not having xfire is pointless with 2 cards.
you should've stayed on the WC setup, heheheI do mine with them, but when they're not mining, I game with them as well.
I could try a PCI cooler, how loud are they?
overlord, I sold the water portion of this rig, I wanted to build up a new project.
Now that I have my xfx crossfired 6950's on air again, I forgot how hot they get, LOL.
MY bottom GPU is OK
My Top GPU temps are
gpu temp - 94C
GPU temp1 - 94C
GPU temp2 - 108C
GPU temp3 - 99.5C
vreg - 79.8C
I am using the XFX bios to 6970, as well as a light, light OC of 840/1250
Is there a better heatsink I can get for these things? Or just go back to stock bios and stock clock speeds?
The fan doesn't help a whole lot, same temps at 100% fan speed and 60%
Yeah, you have to use manual high fan speeds in catalyst to keep it from getting hot. I'd be extremely wary of temps that high, the cards can fail at temps that high.
Using manual fan speeds I can usually keep my 6970 under 50c. I had a previous card die because I failed to use manual fan speed (from overheating).
MY bottom GPU is OK
gpu temp - 94C
GPU temp1 - 94C
GPU temp2 - 108C
GPU temp3 - 99.5C
vreg - 79.8C
Sounds like the cooler isn't set well. You have the right bios, your overclock isn't massive, and fan speed doesn't help much. Sounds like you should take the coolers off and try putting them back together.
Reseated both again, pretty much the same temps. Even with the stock bios.
