6950 X-Fire or 7950/7970
3DVagabond
11,951
204
I'm not sure what happened with crossfire that's made it so bad. Last gen it was touted as wiping the floor with SLI. This gen, it sucks. :\
Be that as it may, I think you should go with a 7900. Once O/C'd they hang with 590/6990. So, they'll give you all of the performance of 2x6950 without having to worry about driver profiles, power usage, noise (if you get a quiet one like the MSI TFIII or Sapphire Dual-X), and you'll get the improvement in features that having a next gen part brings.
Darkrage
233
I have 6950's in crossfire and use them on a dell 30", recently bought a 670 ftw from evga (haven't open it yet)to move to a single card solution, but after reading this thread looks like I should have bought a 7970? I guess the more vram is essential for 2560x1600?
kilroyst
70
So, according to this: http://www.anandtech.com/bench/Product/550?vs=508&i=459.457
the 7970 doesnt have much on the 7950 for Skyrim specifically (I realize the difference is a lot wider for other games) at comparable resolutions, OC not with standing. Along with selling my old card, this would be a fairly economical upgrade, and make me happier until single card solutions that can comfortably push this rez come along, unless theres something I'm not considering?
MTDEW
4,284
37
Nope, i don't think you're "missing" anything.
If i was buying today, i'd easily grab a 7950 over a 7970 and overclock it. :biggrin:
I'd Look at RussianSensation's recent posts on 7950's to figure which 7950 to buy for overclocking.
He's been following them pretty close lately, so i'd trust his brand recommendations.
Shmee
8,313
3,177
I will also say, grab a good 7950 and OC it. GL and HF!
kilroyst
70
Did you pay for a perfect pixel? How much did you pay and from what seller?
I bought the Crossover 27Q. Took 5 days from payment to doorstep from Red-Cap. Screen is perfect, no dead or lazy pixels, no yellow tint, very little backlight bleed from the lower right corner. The color profile was a little cool @ stock, but I tried several profiles from the guys at overclock.net and found one to my liking. Did not pay for 'pixel-perfect'. The seller states that he checks for functionality/outright defective prior to shipping and it was apparent that the box had been opened previously.
I bought a 200W step down transformer from Amazon to avoid any power brick problems for less than 20 bucks. Everything is great so far.
thilanliyan
12,084
2,281
I would go for a single card..the performance you get once overclocked from a 7950/7970 will be roughly equal to dual 6950s.
I can't vouch for all 7950s but the MSI twin frozr models clocks really well. I have mine at 1100mhz at stock voltage, and someone else on this board had similar luck.
cmdrdredd
27,052
357
For a single card the 670 is alright but as I have found through my own testing you have to sacrifice AA or other quality settings to get sustained playable framerates sometimes.
kilroyst
70
Thanks everyone for your input, helped a lot in the decision making process. I will look up those posts MTDEW and decide which 7950 to grab.
I have to laugh...great deal on a monitor necessitates a GPU upgrade...and on...and on...and on. Vicious cycle heh?
RussianSensation
19,458
765
Sapphire Dual-X / Dual-Fan HD7950 and PowerColor PCS+ are the quietest.
MSI TwinFrozr 7950 on HD7970 PCB with 6+8-pin power connector is a great overclocker.
Can't go wrong with any of those.
Here is Review 1, Review 2.
The reason I recommended the 7950 TwinFrozr is because it was the cheapest + great overclocker. However, it's not necessarily better than something like the Sapphire Dual-X 950mhz 7950.
Still, I just checked Amazon, Newegg and Superbiiz and prices have crept back up to the $340-350 level.
The only 7950s to stay away from completely are XFX and reference models.
It's not so much VRAM but memory bandwidth I think.
But ya at current prices, something like the Sapphire Vapor-X HD7970 GE (See Post #18) is definitely worth $50 extra over the GTX670 for 2560x1600 imo.
Xbitlabs recently tested 670/680/7970 GE at 2560x1440 with AA -- Performance Chart:
GTX670 = 48.1 fps
GTX680 = 53.7 fps
GTX670 AMP! = 55.5 fps
HD7970 GE (1050mhz) = 59.4 fps --> but most GE cards can overclock to 1150-1200mhz and that review was done on 12.6 Beta, not 12.7 Betas. :)
GTX670 SLI = 96.4 fps
Here is another review by Computerbase:
At 2560x1600 4AA, 7970 GE is 20% faster than the 670 and if you crank 8AA, that grows to 30% (although for most games that'll be totally unplayable so this 30% is more like 20 vs. 26 fps).
Here is TechReport's summary at 2560x1600:
Darkrage
233
Thank for your answer, I may return it (if I try it out 15% restock for return :( )and go for a 7950/7970 like the original poster or just do what MTDEW is doing and want for next gen. Just wanted to try drivers on the green side lol.
RussianSensation
19,458
765
If you didn't sell the 6950s, and have to outlay $450+ for a new GPU, I'd definitely wait, especially if micro-stutter doesn't bother you.
cmdrdredd
27,052
357
I do like Nvidia's drivers, but at 2560x???? you really need some muscle in the GPU.
