I was looking at some benchmarks at X-bit labs and the 6800nu is almost as fast as the GT at 10x7 at "Pure Speed" (no aa/af), but at like 12x10 or 16x12 at "Eye Candy" (aa/af) it is behind, while sometimes being playable at 12x10. They say that the reason is because of the slow memory on the nu.
I'm guessing "slow memory" is one of these things:
-They might mean it has only 128mb's compared to 256mb's
-It might be because of the GDDR instead of the GDDR3
-It may be because of the slower memory clock speed
-Or, what i'm putting my money on, they mean the 12-pipes instead of the 16-pipe memory bus.
Could you tell me what one they mean, or if it's something different. If it is one of the 2 later that i put down, you can change that with either oc'ing or messing with the bios, so i'm not too worried if that be the case.
And, if you use RiveTuner to unlock those pipes, does it do something physical to the card, or does it just let you use something that unmask something that the hardware hides. And if it just unmasks something, would it accually void the warrenty as long as there are no bios swaps or anything?
Thanks for the help, and sorry if this sounds like a noobs question!
