Everything you pointed out will, most likely, lower Intel's gross margins on the 65nm parts (at least initially), but I doubt it will lead to shortages. Even if yields are horrible at first (it doesnt sound like they are, by the way), Intel has enough manufacturing capacity to basically throw money at the problem until yields reach satisfactory numbers. Efficiencymatters to AMD because it is so capacity constrained, so it has to make the most out of the little it has, while Intel is going to throw two 300mm Fabs at the 65nm process. 65nm parts should take about half the area as 90nm parts (Paxvilles) and the fact that Intel will use dual-die CPU packages instead of dual-core, single-die ones will help out yields tremendously.
The cost of goods sold, of course, is of no relevance to anyone who has no interest in Intel's finanacials (ie. the consumers). If analyzing Intel as an investor, I'd have to point out that though short-term profits will probably suffer a little, the long-term gains of accelerating the 65nm process will be huge. After all, Intel can't even think about introducing the merom/conroe families of CPUs until the 65nm is very mature. Prices on these 65nm CPUs will, most likely, be competitive, since Intel cant afford to alienate any OEMs (nor can it alienate consumers, either) by hiking the prices on 65nm parts too much.
Originally posted by: GFORCE100
There is a difference running a processor at max 2.8GHz and at 3.8GHz not to forget two of them on a dual core Pentium D. If AMD was clocking its chips that high (theoritcally speaking because the design won't allow it) then heat issues would also crop up.
Not quite, the processors are VERY different. If AMD built prescotts for Intel on the same process it builds A64s, the SOI process would lower their leakage quite a bit (I've seen 25% less leakage throw around but I'd take that with a grain of salt). The problem for Intel was the same as ATI's current problems. Intel made a brand new processor (the core was completely redesigned to add more pipeline stages, 64 bits, improved branch prediction, etc), it made it on a brand-new process (90nm) and it threw strained silicon on it, just for kicks. Having so many unknowns will almost invariably lead to problems. AMD, on the other hand, played it safe. It went for SOI before shrinking to 90nm (the hammers), then it went to 90nm (winchester), and finally did dual stress layer (venice). It allowed itself time to get confortable with one tech before jumping onto the next because it was capacity constrained to begin with and wouldn't have been able to survive horrible yields for as long as Intel did.
