Originally posted by: JBDan
ocz and pcp&c are on the verge of releasing 750/850/950! watt PSU's which makes me chuckle lol. Amazing what kinda power is being drawn by pc's nowadays. Look at this beast!! LOL http://www.pcpowerandcooling.c...bout/index_whatnew.htm 850ETX
Personally I think you would be fine with a 510 pcp&c /ocz 520/ or even your 550 true.
Originally posted by: sharkeeper
There is a 800W available, Sharpie® Certified and everything.
Cheers!
Cheers!
LoL, I'd rather take the chance of my 550W pushing it![]()
I would give it a go you might be suprised.![]()
I have the Antec True 550. This is what I've loaded it with, everything running. I was trying to find any instability.
2x SATA 74 GB Raptor, 2x SATA 200 GB Cavair, 2x PATA 250 GB Cavair, 2x Plextor 712a, K8N Neo2 Plat, Winchester @ 2.6 GHz, 2x 512 MB PC 4000 Ballistix, GeForce 6800GT @ Ultra, SB Audigy2 ZS, Linksys Wireless 54GS, 6 Case Fans, Bluetooth & USB Devices, 120W Pelt between two sinks for added load.
I did large file copying between two RAID 0 arrays 200 GB, 74 GB. rthdribl running to load the GeForce. Audigy running with effects enabled to load the SB. Media streaming to load the Wireless NIC. Prime95 running to put any additional load on the CPU.
That was on the True 550. To my amazment, everything ran stable. I ran this load for about two hours. So unless you think you're going to go over that, I think you're safe.![]()
Are there currently any quality 650W PS's on the market? I checked Antec, and they don't have any above 550W.
Mines rated up to 40 COriginally posted by: Gamingphreek
Other than that Zippy is about the only other brand i would buy for this kind of system. Antec simply doesn' thave a PSU rated that high... yet. Enermax although they are nice, they test there PSU's and rate them at 20C a temperature which is not realistic. They are not in the same league as PCP&C and OCZ.
-Kevin
I'm curious, who or where does it say that they rate the operating temp accordingly based on a real life testing temp of 20 C? I've heard older Enermaxs being rated @ 25 C operating temp but never heard 20 C as a temp they test all of their PSUs at.Originally posted by: Gamingphreek
Not what it is rated to, it is what they are tested and rated by. They are tested under cold temperatures, not in a realistic temperature.
I would hope that a PSU can withstand 40C.
-Kevin
