- Jun 8, 2010
- 71
- 0
- 66
I have a Netgear WN111v2 USB 2.0 Wireless N Adapter. The Netgear driver installs on Windows 7 64-bit, but frequently disconnects and never shows more than 2 of 5 bars for signal strength, even though it is at most 20 feet from the router with nothing in the way.
I have a dual-boot configuration with Windows 7 32-bit on the same machine. The adapter never disconnects and always shows 5 of 5 bars for signal strength when I'm using it on the 32-bit side.
My conclusion is that even though it supposedly supports Windows 7 64-bit, it is not truly compatible. Are there any PCI, PCIe or USB Wireless N Adapters that truly are 64-bit compatible? While I'm at it, does anyone know of a similar device that is supported on Windows XP Professional x64 Edition?
-MrCaffeineX
-MrCaffeineX
