6 pin to 4 pin pci-e addapters?
Greka
145
i got pci-e video card, it have 4pin plug, but my pw have special line for pci-e wich is 6pin.. anyone know if there are any cables / adapters for sale? is so what will a name for this cables?
I try to search newegg, cant find..
thank you
framerateuk
224
I bought one cheap off ebay last week, cost about £2.50 including postage. (Just bought a x1900 but it didnt come with the adapter! so i had to nick the one off my 7800GT, which i intended to sell on ebay, but couldnt do so without the adapter :))
Greka
145
In reply to :JBT
info from newegg this is 4pin to 6pin (for use with Video cards requiring the Proprieatary 6 Pin Power connector) ..
I need backwards.. 6pin to 4pin..
Greka
145
i will explane why.
1st - power supply line for pcie comes with 6pin, that line have dedicated 19A power.
2nd - Molex line from psu is 4pin, and its shared, and IT IS 17A power....
3rd - moust pci-e cards need 18A for stable performance...
My video card dont have 6 pin plug, it have 4 pin molex :( .. so here is the problem
Ike0069
4,276
What PSU are you using?
If it only has 17A@+12V, then you should definitely upgrade.
LTC8K6
28,520
1,576
What video card is this?
I can't figure why a PCI-E video card would not have the PCI-E power connector.
I suppose it could be an older early version PCI-E card.
LTC8K6
28,520
1,576
If your card needs the 5V and 12V lines that the 4pin molex connector has, then I am not sure the PCI-E connector can be adapted easily since it lacks the 5V line.
tomt4535
1,758
Just plug a normal molex connector in there. Tuck that connector away somewhere. You wont be able to convert The PCI-E connector to a standard molex like that because it dosent have a 5v line. What PSU are you running?
tomt4535
1,758
Originally posted by: Greka
PSU is a Antec SmartPower 2.0 SP-500 ATX12V 500W, ( Modular) http://www.newegg.com/Product/Product.asp?Item=N82E16817103937
I dont think video card is using 5 volt, but it is possible. i will have email to XFX support.
With that PSU, you should be fine. Just plug one of the normal molex connectors into the card. That psu is modular so you wont even have to plug in the PCI-E connector.
Greka
145
thanks for sugestion, monday my 2nd pci-e card will be delivered. I will try to configure Dual SLI, u think it would support 2 cards?
JBT
12,094
With a card like the 6800 GS I really wouldn't worry about using it on its own cable. If you were using a more powwerful card that was alot more power hungry sure but not a GS card...
Greka
145
its XFX PVT42EUDE3 Geforce 6800 XTreme 256MB GDDR3 PCI Express x16, will have 2 cards SLI - waiting for one to come back from RMA, and ordered 2nd card. so i will have 2 cards SLI.. in my DFI LanParty SLI-D
