MDE
Originally posted by: jiffylube1024
Originally posted by: Vonkhan
Originally posted by: Nebor
I think a stone drops at the same rate no matter the depth of water it's in. Physics guys, back me up.
Wrong again Nebor. I could go into detail, but its not worth it ... u have to figure in the factors whether the stone was in motion before it hit the water, or was it static ... well, utilmately, it'll reach terminal velocity (uniform speed) at which it'll be sinking
No, he actually is right (assuming you're talking about dropping from rest at both points). Ie, a stone going from rest to dropping from just below the water's surface will have the same speed as one dropped from 100 feet below.
Of course if this is the same stone we're talking about then obviously it will be faster at the lower point due to acceleration as long as terminal velocity has not yet been reached in the first case.
But he is right, the stone drops at the same rate (ie acceleration) no matter where it is in the water. And in this sense he is right about deep water making no difference - the depth of the water does not matter on the stone's rate of descent.
Nebor is right if you disregard turbulence and resistance from the water.
