He already mentioned that he wants to send audio over HDMI, so DVI won't work for him.
What I meant was that he should use HDMI strictly for audio and DVI for video.
Actually I can still get audio over my HDMI cables and send video to my monitor from my DVI cable. I was just interested in reducing the amount of cables I'm using. No one likes clutter.
ding ding ding. that's the easiest solution. no one likes clutter, true, but you'd have shorter signal paths with 2 cables, one going directly to the tv, the other going directly to the receiver. besides, unless i'm mistaken, wouldn't your setup be something like this:
using hdmi for audio and video:
1. radeon > hdmi > receiver (audio) > hdmi (presumably) > monitor
or
2. radeon > hdmi > monitor (video) > hdmi (or s/pdif) > receiver (audio)
^the former is definitely preferable to the latter.
alternatively, using 2 cables from the video card:
radeon
> dvi > monitor (video)
unless i'm missing something, you're using 2 cables either way, it's just displacing the clutter. having the audio go straight from the video card to the receiver and video straight from the card to the monitor is the best solution, minimizing all signal paths and ensuring that all of the a/v data is being transmitted over the highest quality connections.
