585W Power Supply Promotion @ $14.99
kasia00
200
Got this PSU @ mwave. For $14.99 yesterday the
ORION HP585DR
Compared prices all over TIgerdirect has it for 59.99 and great feedbacks!
Anyway... there it is
esquared
Forum Director
Oct 8, 2000
25,297
6,339
Ground shipping looks to be 8-10 depending where you live.
BIGFOOTPI
1,029
limit 1 - bah! useless for qty purchase to soften the price per psu by combined shipping...
it was $16.99 limit 5 before. Oh well... guess I won't be getting any now. (was going to get 5 for the shop)
Zap
22,377
7
Originally posted by: Modular
Temperature Range Operating 0°C~35°C,
The failure rate possibility is strong with this one.
Not too terrible as many cheaper (and even some expensive) power supplies are rated at 25ºC for their "rated" wattage even though most PSUs get much hotter. These PSUs do have two rather noisy 80mm fans in push/pull configuration to keep them cool running. Well, noisy if you're into "quiet" computing. Their PCI-E 6 pin plug is actually an adaptor that comes with the PSU. Also, because of their dual fans, this PSU is a bit deeper than the normal 140mm depth.
IMO HEC PSUs are a step above the really crappy PSUs so if you just need something for a budget system that won't blow up on you, then this will work okay. Don't expect to run an overclocked quad core with dual 8800GTX on this though.
