56K modem problem with AOL
BACKGROUND:
Sister's computer.
Normally she's on my LAN at home but she's house sitting for someone. Only thing available is dialup. And she likes AOL.
I install a modem, installs fine, and works for a couple months.
THE PROBLEM:
Then she calls me, says it stormed, computer was on and ever since she can't connect.
I investigate, and it will dial, do the crap noise, but just hang there forever until it timeouts.
There is a computer at the house and it uses AOL to dial up and it works just fine.
TRIED SOLUTIONS:
I take the computer to my house, does the same (TRIED DIFFERENT PHONE LINE)
I take the modem, move it to a different PCI slot (TRIED DIFFERENT PCI SLOT)
I setup AOL to use different numbers (TRIED DIFFERENT ACCESS NUMBERS)
I reinstall AOL, (TRIED REINSTALLING PROGRAM)
I replace the modem (TRIED REPLACING MODEM)
The new modem does the exact same thing.
Any ideas on what to try next before I reformat/reinstall everything on her computer?
The problem is with Dial-Up Adapter.
(more than likely duplicate settings in the REGISTRY)
Remove all the AOL Dial-Up shortcuts, remove Dial-Up Adapter,
remove AOL software.
Reboot and reinstall everything.
I'll give that a shot this afternoon and report back.
I did something similar. OS is Win XP. I found an AOL connection in her network places and deleted that, thinking AOL would install it again when I reinstalled AOL. It did not.
well, I just made a lengthy reply and then noticed you tried replacing the modem already.
so i deleted my post
nevermind.
