$500 Upgrade Plan possible?
Originally posted by: BigfootsMonk
Well, about that post that suggested that I should wait for the next generation cards, when will they come out?
Probably be announced in July, availible in September (just a guess).
How do you tell if they're good or bad? This one seems fine so far.
Should I use the 580W Powmax for the 2nd computer and get another one for the 64 machine? Wanna recommend me one?
ok can you recommend me one that would be more than enough for the A64 as well as room for expansion?
Will the current Powmax be enough for the second computer?
