Salacious Sith
So my current Ultra 500w PSU should be fine to power 2 7800GT cards, 1-2GB of RAM, AMD64 3700+, and 3 HDs...right?
Originally posted by: potato28
Id be careful using that PSU and having expensive equipment like that... OP buy the 500W Seasonic. Effecient, quiet, and a good price.
Originally posted by: Bobthelost
A single 7800gt requires 26 A on 12v rail dunno what 2 would require but I would get a 600W PSU to be on the safe side.
Like hell it does.
Yes! Your Graphics card draws a stunning 312W on it's own! That's even more than an FX-60, motheboard, 2gb of RAM, a DVDRW, couple of hard dives and a 1900XT!
For those of you who missed the sarcasm there, the poster above me is utterly wrong, it does not draw 26A on a sinlge rail, or even spread over two rails.
Really? Convince me why....
Like hell it does.
Your comparing Amps to wattage? I believe this is incorrect. AMPS measure the amount of power is coming through not how much power there is. Also someone who said you dont need 26amps on the 12v and that you're only running 18amps, thats probably because you have a dual 12v which has a combined of 36amps.
If you are running Dual cards, buy an sli certified and you should be fine. You will see that almost all sli certified PSU's are dual 12v with at least 18amps each.
Originally posted by: Smartazz
Can anyone recommend a good 500 watt psu for it, preferrably around $100.
Your money (computer parts) is that dog. The chair is your ignorance.
It might give you 500w if you hose conditioned air into it, and it has super stable AC through a faraday with a regulated UPS. It has a similar chance of spontaneously polymorphing into the messiah.
Originally posted by: Yoshi911
it's a $100 PSU and has good reviews, thank you very much 😛 lol. But I need a real answer, if it isn't a good one than I'll sell it on ebay for $80 and buy OCZ
Originally posted by: XabanakFanatik
I also motion for the SeaSonic S12-600. It's a great PSU.
For the sake of the argument in this thread - I've been running a 7800 GTX, 3200+ at 2.8 GHz, 2 optical drives, 3 SATA drives, 1 Raptor and 4 120mm fans on a PSU with 17 amps on the +12v rail. Is that not enough proof that you don't need 26 amps to run a 7800 GT?
I've had several disks drop out of a RAID 5 array because of the PSUs. That is the reason why I run dual power supplies (1 Seasonic 600w & 1 Seasonic 500w). I can never stress having a good PSU enough.
But Dude, You have a HUGE PC. Basically don't try to push more than %60-%70 of your Psu's quoted Watts? Would that be a fair principal to go by? (of course ommitting the crap $20-$50psu's pawned off on Ebay)
Originally posted by: Boyo
The reviews that I read on the S12 Seasonic was that it was extremely loud, so that is why I avoided it. I know that it got top honors on this website and Tom's Hardware, but it was the noise factor that kept me away.
Am I wrong on this??? Otherwise that was the PSU I originally picked out. The reviews I read were on Newegg.....Anyone???
