$5 PAYPAL TO FIRST PERSON WHO SOLVES THIS PROBLEM
Go into the sound drivers..
Where it says joystick, switch from digtal to analog. I donno this sometimes causes problems for me when it is digital...
<< turn off "Smooth Scrolling" under the IE options, it's definately a graphics prob, I had a similar issue with my laptop (pentium3m-850, 512mb ram) under winxp. that fixed it for me. >>
SWEEEEEET. That worked!
I turned the smooth scrolling off and it did make a difference, but by no means did it solve the problem. The music still slows down and skips, just not quite as much. Those of you suggesting I try a separate sound card, please reread the post, I already tried that and it did not help. Installing a PCI video card did seem to help, but as I said in the original post, I need this problem solved without adding new hardware. Thanks for the research Justin, I will try using Winamp to see if it plays the midi files any better, but as I said in the original post, I need to get it working with Windows Media Player.
Have you ruled out your antivirus software ? We use McAfee at work and there was a corrupted dat file that slowed certain tasks to a crawl on our work PC's. If you haven't tried it, either update your antivirus dats or disable it temporarily to see if that is affecting anything. It slows my P3/866 - 256 RAM PC when Winamp is playing and I open Corel or OE5. Hope you get it fixed soon 🙂
Changing the Color Quality from Highest (32 bit) to Medium (16 bit) [Display Properties-->Settings] nearly eliminates the sound distortion while scrolling with internet explorer. The only real distortion now occurs only when I "grab" the scrollbar and yank it up and down. Funny, I can play midi files on lesser machines without any distortion, no matter what I do, yet this machine always has at least a little distortion. By the way, I replaced the 1GHz Duron with a 1.3GHz Duron and that made no difference whatsoever. I did build a machine last week though with the same motherboard and a 1.33GHz Athlon, and that machine played the midi file without any problems.
Have you tried to reduce the graphics acceleration or the sound acceleration or both? Either one of those will most likely fix your problem.
<< Have you tried to reduce the graphics acceleration or the sound acceleration or both? Either one of those will most likely fix your problem. >>
Si, and reduce the number times per second when your mouse is updated (from 20-100/s).
Ugh, I've got this exact same problem when listening to mp3s. It doesn't matter what program I use to listen to them, IE6 makes them skip and pop. Something that I've yet to try that I think I will is to move my sound card to different PCI slots, sometimes this can help.
