i cant actually...flash mx 2004 only saves as MX files
but here is the code that needed to be changed:
bytes_loaded = Math.round(this.getBytesLoaded());
bytes_total = Math.round(this.getBytesTotal());
getPercent = bytes_loaded / bytes_total;
this.bar._width = (getPercent) *80; // take percentage loaded and multiple by total width of bar
if (bytes_loaded == bytes_total) {
this.gotoAndPlay(3);
apart from that the only difference was chaging the registration point of the "bar" (open the movieclip from the library and move the bar so that its left hand edge touches the + symbol for the center of the stage)
