Scarpozzi
- Jun 13, 2000
- 26,389
- 1,778
- 126
It could be the capacitor. You can look at the capacitor to see if there are signs of bulging or electrical damage or just replace it.Scarpozzi, I checked twice - although my 1st floor AC is set to on, the fan outside is not moving! Does that mean it is the capacitor?
Thanks!!!
EDIT: When mine failed, you could hear the motor surging when it was trying to spin up, but the capacitor wasn't supplying the surge of voltage it needed to give the motor the push it needed.
If you disconnect the power from the outdoor breaker (should be mounted on the wall), you can take the panel off the side of the unit and inspect the capacitors. If you want to try to try to replace them yourself, you can read the side of the cap to see exactly what you would need. Their useful life is only typically 10,000 cycles I think. Mine lasted less than 10 years, but it's the most common issue for a system to just all of the sudden stop cooling. Any HVAC guy could tell you that. You can get a better picture idea by searching "HVAC capacitor replacement" on youtube.
Ordering a new one and replacing it yourself would take less than 30 minutes and be like $20....or you can pay someone. I'm not sure what they charge, but it shouldn't be that expensive if they're not ripoff artists. Half of the battle is convincing them that you know what's wrong and they can't make you pay more than what the job is worth. ($standard fee + part + install.....maybe $300 or less? All depends on where you live.)
