Originally posted by: drinkmorejava
5.1 plus HD280s
Same here (though your 5.1 is probably better than mine, i just have a creative masterworks THX 550 setup), gotta love the sennheiser cans for high fi listening though.
5.1 plus HD280s
If the mains start to roll off around 45hz you should consider placing the crossover at 55hz. It's quite likely you'll get a flatter frequency response this way.Originally posted by: Goosemaster
Originally posted by: BornStar18
What speakers do you have?Originally posted by: Goosemaster
Originally posted by: Raduque
I use 2.0, yes that's right, straight stereo. My mains are flat at 90db down to 35hz, and 88db to 30hz. For music only 😀
My HT is a 5.1, i don't even care abotu the measurements, because it's an Onkyo HTIB and sounds "good enough" for now.
:thumbsup:
I jsut decided that since my mains bottom out at ~35-45 hz, they needed extra help, so I run my maisn down to 45 and my sub below that.
I sounds scrumptious.
Rhapsody in Blue is FANTASTIC on this thing.
Sadly, I hate all the matrixed surround modes out there and have never had the pleasure if hearing HK's logic 7 in action..I hear it is delicious.
Some Mirages.....
I have an Athena Sub I got for a bargain...doesn't live up to my mains but it still kicks ass..😀
:thumbsup:
Some Mirages.....
:thumbsup:
Some Mirages.....
:thumbsup:
Some Mirages.....
Mirages? Would they happen to be FRX-7's?
Originally posted by: Baked
I like my Sennheiser HD650. And maybe that's why I have severe hearing problems. Sometimes I turn on the stereo to give the B&W 602 S3 a work out. Don't have space for 5.1 setup.
Then that works. I'm not even sure my reciever has a place to change the crossover but since I don't use a sub, that doesn't really matter.Originally posted by: Goosemaster
:thumbsup:
Some Mirages.....
Unfortuantely that is not possible since my reciever can only do 80 100 and 120🙁
That is why I recently switched from having my crossover at 80hz at just set my mains to full and adjusted the sub accordingly.
For the msot part I liek it better thsi way..the bass from my mains is so beautiful and rich sounding
:thumbsup:
Some Mirages.....
You have my deepest respect anyways for having some 602's😀
Hehe, I haven't turned them on for months. >_< I should put some Tool on this weekend and warm them up a little.
:thumbsup:
Some Mirages.....
5's. I wanted 7's since they had more drivers but mine are large and in thend, a lot of people told me that it was the right choice.
yeah, they are on the lower end of the Mirage lineup, but they wipe to floor with a LOT of good stuff.....and they way a ton😉 (MASSIVE magnets😀 )
Honestly, as you hinted at, flatness is good, and these are some of the most neutral speakers, which I don't ahve to worry about anything.
<---never EVER uses an EQ.
:thumbsup:
Some Mirages.....
Nice speakers :thumbsup: 🙂
I've got a pair of the FRX-7's and the LF-150 sub to reinforce the low end. 😛
You couldn't have said it better; they are better than a lot of higher priced speakers. I know that ever since I had these I have had no want or need to look into getting anything to replace them.
Goosemaster, mind if I ask what you're using for a Receiver and surrounds/sub?
I've heard good about Atena subs. But you haven't heard anything until you've stacked a LF-100 & LF-150 😛
5.1 plus HD280s
MAKES NO SENSE!
5.1 plus HD280s
MAKES NO SENSE!
um, yes it does, Banzai042 got it.
I have a 5.1 surround setup and I also have a set of sennheiser HD280 cans. Come on, you're required to know all Sennheiser model numbers in an audio thread.
they also double as GREAT Earmuffs in the winter😀
