It goes from the PC to an optical 3-input switcher under the TV itself from where it then goes to the other meter and a half to the receiver.Is the optical connection not on your receiver?
Got all the cables, setting that up. But, is there any way to continue to get sound to my PC speakers when I'm at the desktop? The speaker plug for my desktop speakers is in use by the RCA-minijack cable.not sure why you don't connect by analog to your receiver from the board
Ok, thanks. Letting the speakers come from the front panel is gonna require a right angle minijack plug or else it's going to get whacked because of where the desktop sits. So, while that ships from Amazon, I'm just swapping from the back socket.If your front panel is hooked up you can plug the speakers into the headphone socket when you want to use them. You should be able to configure the soundcard's software to disable the other outputs when the headphone socket is in use, or not depending on your preference.
...just trying that. 😉What happens if you swap the rca cable?
